still no fire day two 87 2.8 camaro - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 11th, 06, 03:26 PM Thread Starter
I have changed the module, coil, cap, rotor.
The coil has power to it and power is going to the bottom of the distrib.
It still seems odd that I dont get any Oil, Alt, Temp lights on the dash when I first turn on the key.
the buzzer sounds and I do get a brake and check eng light on the lower dash
Would this modle have some type of shut off for low oil press.
Could it be in the ing switch?
Thanks for your help
IBNFECPO is offline
post #2 of 4 (permalink) Old Jan 12th, 06, 03:07 AM
Re: still no fire day two 87 2.8 camaro
Things to check:
1. Power to dist when in the start position?
2. Fuel pump working? When IGN sw goes to IGN, you should hear the fuel pump running for 2 seconds, ECM controlled. Fuel relay is up by the drvr hood hinge.
3. Broken fusible link at the starter solenoid terminal.
4. Oil pressure sending unit broken? There is a set of extra terminals to power fuel pump relay when oil pressure gets above 15 PSI, if the f/pump relay doesn't run under normal conditions.
5. I don't think it could be the ign switch, but one would never knows.
post #3 of 4 (permalink) Old Jan 13th, 06, 08:34 AM
Motors need 3 things to run.... GAS,SPARK,AIR.... You can check the spark by placing a timing light on the spark plug wire and attempting to start it. The light should blink a couple of times a sec.. Gas metering is controled by the computer.. can you check to see if it has any code faults..? is the thottle body getting gas.. it will usually puddle a bit on the throttle butterflys.
Long Gone: 1984 Z28, 1989 RS
Current : 1967 Coupe w/350, 2010 2SS
My Photobucket >>
dragon0123 is offline
post #4 of 4 (permalink) Old Jan 14th, 06, 03:12 PM Thread Starter
Re: fire fire fire day four 87 2.8 camaro
I would like to thank all of you for your help.
I changed the distrib and she fired right up.
Im sure it was the pick up coil because it was the only thig I had not changed.
It seems like water collects really easy under the distrib cap.
The whole assy was severly corr when I fist looked at it.
Again thaks for your help.
IBNFECPO is offline
