1969 SS fuse panel - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 13th, 06, 12:52 PM Thread Starter
Chris
1969 SS fuse panel
Dose anyone know the correct order of the fuses in the fuse panel assembly located just up and behind the brake peddle? The names (horn, lights, etc...) have worn off next to each fuse. Any help would be appreciated. Thanks!!
chriss69 is offline
post #2 of 7 (permalink) Old Jan 13th, 06, 02:06 PM
Charles
Re: 1969 SS fuse panel
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #3 of 7 (permalink) Old Jan 13th, 06, 03:02 PM
Harry
dawg's Avatar
judging from the looks of that panel I wouldnt bother.
get a new harness or else your in for alot of headaches
434 stroker
US Navy retired
dawg is offline
post #4 of 7 (permalink) Old Jan 13th, 06, 03:36 PM
Charles
the pic is for chriss69's reference only. i have a brand new block in my 69.
Run269 is offline
post #5 of 7 (permalink) Old Jan 16th, 06, 07:02 AM Thread Starter
Chris
Thanks for the pic!! My panel is in only slightly better condition than the one pictured, where should I look to get a new one?
chriss69 is offline
post #6 of 7 (permalink) Old Jan 16th, 06, 07:56 AM
Charles
i got mine from www.americanautowire.com. they will probably give you the run around about selling the entire harness, but they WILL sell only the block with new fuse clips on the backside. just keep calling and telling them you want only the block. you will have to specify A/C or non-A/C as there is a difference on the backside.
you will have to cut and splice most of your old wires into the new block. i suggest soldering everything to reduce any problems down the road. some wires just clip on, make sure you clean up those connectors. i believe i paid about $75 for the new block.
do not push the new fuse clips into the block until you are absolutely positive you are ready, as removing the clips from the block without the proper tool will destroy the block.
take pics of the backside of both new and old blocks before starting to change wires over. it gets confusing with all the wires going into the block. get a schematic and double check everything twice. turning your radio on and having the windshield wipers work will frustrate you to no end.
here's a pic of the backside of the new block. you can see the connectors are ready to splice in the new wires. all shiny and beautiful.
Run269 is offline
post #7 of 7 (permalink) Old Jan 16th, 06, 09:42 AM Thread Starter
Chris
Wow!! Looks nice. I'll check them out.
chriss69 is offline
