horn relay - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 14th, 06, 06:58 AM Thread Starter
Jan
horn relay
Can anyone show me a pick of a horn relay and explain where it's located? Also, are there any modern relays that can serve as replacement?
67 Swedish Convertible
67 Swedish Convertible is offline
post #2 of 4 (permalink) Old Jan 14th, 06, 07:25 AM
Re: horn relay
my pleasure, here ya go:
As far as modern relays, I suppose anything is possible if you want to cob something together, but the correct relay is readily available, so why bother?
The pic is of the relay detahced, hanging from it's wires. It mounts on the firewall side of the rad support, drivers side, below the regulator. It mounts with the wires hanging down, with a 1/4" self tap screw. There's a second small hole for a locating tab.
The screw connections include the main battery feed (12 red) and the feed to the fuse box (12 red with black fusible link.) Cars with guages, a/c, power top or windows will have additikonal wire(s) on the screw connections.
Plug connections are green to horns and black to horn button. 68-69 also have a pink wire with a black stripe for the key buzzer.
ID:	276   Click image for larger version
post #3 of 4 (permalink) Old Jan 15th, 06, 01:51 AM Thread Starter
Jan
Re: horn relay
Thanks for that JimM!
post #4 of 4 (permalink) Old Jan 16th, 06, 08:00 AM
Chris
Re: horn relay
Does the horn have it's own fuse?
chriss69 is offline
