courtesy light confusion - Team Camaro Tech
post #1 of 1 (permalink) Old Jan 14th, 06, 05:21 PM Thread Starter
I'm installing courtesy lights under the dash area in a 69. I purchased the light harness. The confusion comes into play when I found orange and white wires on the right side of the dash area, that are plugging into a T connection - the wires have been cut approx. 3" after the connector. This connection is approx. 4" away from the right side courtesy light bracket. The connector has a small steel clip on it. If I disconnect the old T connection, the new one will not match-up -- it's the wrong gendor end.
I understand from reading other posts that the connection should be on the driver's side. I'm I maybe looking at the wrong connection??
Any help is appreciated; thanks guys.
utility5 is offline
