Console gages (temp/amp) not working? - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 16th, 06, 09:19 PM Thread Starter
Brad
Question Console gages (temp/amp) not working?
Both temp and amp console gages do not appear to be working. Is there something in common between the two gages that could make they inoperable? Do they work off a fuse together?
Camaroless and hating it
chedderboy is offline
post #2 of 6 (permalink) Old Jan 16th, 06, 09:37 PM
john
wagonman's Avatar
Re: Console gages (temp/amp) not working?
make sure that your ground wire inside the console has a good connection...does the fuel gauge work ok? also do the gauges fluctuate when you turn on your lights? these are all indications of a poor console ground...
wagonman is offline
post #3 of 6 (permalink) Old Jan 16th, 06, 09:43 PM
Charles
i believe there is a short ground wire jumping from the front pair of gauges to the rear pair on the underside.
do a search for low fuel module. somebody on here has an excellant pic of the backside of their gauges.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #4 of 6 (permalink) Old Jan 17th, 06, 09:06 AM
click's Avatar
There are several pics of the back of my guage cluster in this list, go thru them all
pics of guages and other
click is offline
post #5 of 6 (permalink) Old Jan 17th, 06, 11:35 AM
Turn your parking lights on...... If the lights for the gauges do not light up, then you have a bad ground.
Camaro buds until the end!!!
Camaro Dave is offline
post #6 of 6 (permalink) Old Jan 18th, 06, 04:06 PM
Larry
BTW, there is no connection between the two gauges.
Larry
69-er is offline
