Help me find the 12V wire to hook my fan up please - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 21st, 06, 07:41 PM Thread Starter
Well, I under took my project today and finished the install of all the parts. I have a Mark VIII fan and I am trying to find were to plug it into. I have a test light and couldnt get it to light up even with ACC mode with all the wires in the engine bay. I added a 100amp alternator. So I ran a wire from my fuse box (Radio) witch I knew ran in ACC and was 12V. Tested the wire with the Test light and it light up bright. So I hooked it all up and it blew a fuse. Any ideas?
Spent all day working on my car and LOVE to get this finished.
Thanks,
Jon
Indpowr is offline
post #2 of 12 (permalink) Old Jan 21st, 06, 09:20 PM
Re: Help me find the 12V wire to hook my fan up please
Electric fans draw much more current that ACC fuses and wiring would handle. That's why the fuse is blowing. Hopefully someone on here can help with where to find a suitable power point.
Riccbhard is offline
post #3 of 12 (permalink) Old Jan 21st, 06, 09:27 PM
you need to use a relay to power the fan
this drawing i did a while back should help, if you dont want to use a temp sensor and just want the fans on anytime, ground that wire
400bird is offline
post #4 of 12 (permalink) Old Jan 21st, 06, 09:40 PM Thread Starter
Thanks 400 bird.
So is the 70amp Relay the best? I have a relay in the car now but I think it burned up. Is that possible? It has about 5 wires coming out of it. Is there anything else that maybe wired into the relay? I used a test light on it and it does not light up in ACC or running.
Jon
Indpowr is offline
post #5 of 12 (permalink) Old Jan 21st, 06, 11:40 PM Thread Starter
Few more questions on your drawing.
Fan + (I know where that goes)
Bolt + [Fuse] (Where does this wire go to)
Ing + (Where do I find the ING wire)
Temp Sensor (I think I can figure this one out)
Sorry to sound like a newbie but I am when it comes to electronics.
Jon
Indpowr is offline
post #6 of 12 (permalink) Old Jan 22nd, 06, 12:04 AM
Sean
-the "batt" (not bolt, but thats probably what you meant) can go to the battery itself, or the horn relay has a buss on it that has battery power. be sure to put a fuse in line, before the relay.
-the "ign" (not ing. but.... see above) goes to a source that is on when the car ignition is on, and off when its off. a good source is one of the terminals at the fuse box labeled "ign". just test with a tester, you'll find one.
don't worry about asking, none of us were born knowing these things
Sean
Franklin D. Roosevelt
68rs406 is offline
post #7 of 12 (permalink) Old Jan 22nd, 06, 03:09 PM
68rs has it right, and i never even noticed the typo for ign...
and the temp sensor should not be the one that is already in the motor(for the gauges or idiot light), you need to get one for an electric fan
go to summit and search for "electric fan sending units"
just pick one for what temp you want to fan to cycle on and off at
and i dont know what that relay is for, maybe power windows, power top, horn relay, some aftermarket add on, dont know without a discription...
i got my relay from autozone, i think, but i had to order it online
and dont worry about the questions, i had to be taught all this stuff too
400bird is offline
post #8 of 12 (permalink) Old Jan 22nd, 06, 04:52 PM Thread Starter
YOU GUYS ROCK....
Thanks so much, I finished my car today and took it out for a long drive. It was flawless. Never touched 200 the entire time (Even heavy traffic) This was the FIRST time I drove the car since I bought it without a problem.
I think I toasted my alternator though. I need to jump the car when I start it. When I first hooked up the fan I used the red wire right off the alternator. My amp guage in the car shows 0 amps all the time. I guess thats the price of learning but it was worth it.
Thanks again guys.
Jon
Indpowr is offline
post #9 of 12 (permalink) Old Jan 22nd, 06, 06:52 PM
Not sure what alternator you'll need, but a stock one won't keep up with the fan and other accessories. You'll need something like a CS130.
dnult is offline
post #10 of 12 (permalink) Old Jan 22nd, 06, 09:43 PM
glad to here you had a great drive
you should not use the wire on the alternator, the huge spike when the fan turns on may be harmful to your alternator
if you are going to upgrade your alternator, look for an internal regulated, 100amp or more alternator, i have a power master and have been happy with it, got it from summit
and i would recomend getting a voltage gauge (not amp gauge), so you can know how the alternator is actualy working, but the amp gauge is better than nothing
let us know if we can help any more
400bird is offline
post #11 of 12 (permalink) Old Jan 23rd, 06, 07:15 AM
Chris
Cool Re: Help me find the 12V wire to hook my fan up please
You need to wire the fan directly to the battery via a powered relay. The relay can be activated by any point that is ignition fused. Painless Wiring and Flex-A-Lite both sell pretty good kits that come with instructions on how to wire up the fan.
Good Luck
1967 Chevelle 496BB/TH400/Dana-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Daily Driver)
1967 C10 Short-Wide 496BB/TH400/12-bolt (The Shop Truck)
2008 Harley Davidson Dyna Low Rider
Chris @
Motorhead62 is offline
post #12 of 12 (permalink) Old Jan 23rd, 06, 08:04 AM
BonzoHansen's Avatar
I'll say it should go to the point of power distribution, probably the horn relay, but I ran the one on my 82 to the battery with no problems.
http://www.madelectrical.com/index.shtml
TC Member #13
BonzoHansen is offline
