magnetic pickup trigger - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 28th, 06, 04:42 PM Thread Starter
I'm installing a 6AL ProcompElectronics ignition box. My distributor is a GM HEI 4 pin module. There is a 3 wire (brown, black, yellow) harness coming out of the distributor. Which of these three does the purple & green wire coming from the ignition box connect to?
I've looked at the MSD site, but, because this is a generic ignition box modeled after the 6AL, there is not a PN8860 connector between them. Also the MSD site has the 4 pin module replaced. Do I need to do this?
Baloo is offline
post #2 of 2 (permalink) Old Jan 29th, 06, 06:08 PM Thread Starter
Thumbs up Re: magnetic pickup trigger
Okay, I figured it out. I removed the 4 pin module and condensor from the distributor per the MSD instructions and wired the purple & green wire inside the distributor to the 2 wires on the pickup trigger. Everything fired up perfectly and now my Tach works too!!
Baloo is offline
