Tach problems - Team Camaro Tech
post #1 of 9 (permalink) Old Jan 31st, 06, 07:37 PM Thread Starter
Tach problems
My 68 factory tic toc tach does not work properly.Also the tach does not seem to respond with the engine RPMs,And does not FALL back down to idle rpms after it is revied up.Only when I shut off the car it falls to zero on the gauge.I am Running a MSD pro billet {ready to run distributor} and a MSD 6AL.I tried everything,calling MSD, to tach adaptors, nothing has worked. I cut the tach wire that went to the original coil and connected it to the 6al box and adaptors,and still it does not work properly. Iam wondering if my tach is bad. Is there a way to bench test the tach? Or check it.
Hammer49 is offline
post #2 of 9 (permalink) Old Jan 31st, 06, 07:42 PM
Re: Tach problems
I Would Say The Easiest Way Is Too Drop The Old Distrbutor Back In For All It Takes Withoutany Msd Stuff...run Engine And Check Your Tach With A Tach/dwell Meter Or Borrow A Buddies Tach Hook Both Up And Compare
pro1 is offline
post #3 of 9 (permalink) Old Jan 31st, 06, 07:55 PM
Re: Tach problems
my repro tic toc w/msd rtr (no 6al box) had similar problems. I built this out of radio shack stuff and it fixed it. Seems you tried about everything, but i thought i'd throw it out there anyway.
http://home.comcast.net/~Jimragtop/tachfilter/index.htm
post #4 of 9 (permalink) Old Jan 31st, 06, 07:56 PM Thread Starter
Re: Tach problems
Sorry for the double post,I tried to delete it, but don't know how.
You know I never thought of that,{putting in the original distributor}.So if its bad, Any Suggestions on a place to fix it.
Hammer49 is offline
post #5 of 9 (permalink) Old Jan 31st, 06, 07:59 PM Thread Starter
Re: Tach problems
Thanks JimM I will try anything about now.
Hammer49 is offline
post #6 of 9 (permalink) Old Jan 31st, 06, 08:07 PM
Re: Tach problems
Ya Phone Craig At This No........1716 652 7086........if I Recall Talking To Him He Sends Them Out For Repair........hey Its Only A Phone Call
pro1 is offline
post #7 of 9 (permalink) Old Jan 31st, 06, 08:18 PM Thread Starter
Re: Tach problems
Thanks Pro1,
Hey JimM if your still out there I love to see how you mounted your alternator with those headers and a pic of it if you have one.I have the same valve covers less the color,cool idea.Nice Web Site.
Hammer49 is offline
post #8 of 9 (permalink) Old Jan 31st, 06, 08:25 PM
Re: Tach problems
Most Header Companies Sell You All The Bracket You Need.years Ago They Would Throw Them In...its A Bracket That Bolts To Your Alternator Factory Bracket And Then Slides Over The Header Pipe And Bolts On The Header Bolts
pro1 is offline
post #9 of 9 (permalink) Old Jan 31st, 06, 08:34 PM Thread Starter
Re: Tach problems
Thats what I used on mind but I had to modify it because I installed a CS130 Alt.
Just browsing for new ideas.
Hammer49 is offline
