Where should I drill the holes in the trunk pan for the 68 RS backup light grommet? - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 3rd, 06, 11:25 AM Thread Starter
I replaced my 68 RS trunk pan, and I would like to know the proper location to drill the holes for the backup light wire/grommet. Other threads on this site show the 69 RS wire hole to be on the outside of the trunk brace. I don't this is correct for 68 due to the location of the lights and the length of the wire. My old pan was mashed up and poorly repaired, but seemed to have the holes down in the pan itself, not up on the 'shelf' and on the rounded corner part of the back of the pan. Can anyone help here, or post or send a photo? Are both sides' holes in the same mirror image location? Thanks to anyone that can help - I also posted this question in the Body Shop forum, because I'm not sure which forum is correct for this question.
ggkeller is offline
post #2 of 9 (permalink) Old Feb 3rd, 06, 12:07 PM
Re: Where should I drill the holes in the trunk pan for the 68 RS backup light grommet?
I would have to look at my 67 again but, I am thinking from memory that it is on the outside of the bumper bracket on the shelf part of the trunk. 67-69 should all be the same.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 9 (permalink) Old Feb 3rd, 06, 12:09 PM
Christropher
Check out this thread, has some good pictures of where it should be.
https://www.camaros.net/forums/showth...hlight=grommet
Christropher
...in pieces still.
clwilcox33 is offline
post #4 of 9 (permalink) Old Feb 3rd, 06, 03:58 PM Thread Starter
Thanks for the replys so far. I still question the holes being on the outboard side of the bumper brackets on a '68 because the length of the backup light wires and location of the grommet on the wires doesn't look it would reach under the frame rail end up to the trunk floor. The lights are on the inboard side of the frame rails. Anyone's help here would be appreciated.
Thanks.
ggkeller is offline
post #5 of 9 (permalink) Old Feb 3rd, 06, 05:24 PM
Randy
rs1968ss's Avatar
Mine are on the inboard side of the frame rails. They are about 1-3/4" in from the rail. The trunk pan has a flat area right next to the frame rail and then a slight dip to another flat area before dropping off into the trunk pan. My grommets are in this middle flat area.
Hope that helps.
-Randy
rs1968ss is offline
post #6 of 9 (permalink) Old Feb 3rd, 06, 05:35 PM
Kevin
sleepsinshed's Avatar
Here's a pic of the wire/grommet on my 68.
Hope this helps.
Kevin
Kevin
sleepsinshed is offline
post #7 of 9 (permalink) Old Feb 3rd, 06, 10:44 PM Thread Starter
Randy and Kevin, Thanks for the information, and especially for the photo Kevin. This seems to confirm what I had thought about the '68 location. I assume that the '67 may be the same. All the other posts on the site refer to the '69 location, which now is confirmed to be different than the first two years. Thanks again.
ggkeller is offline
post #8 of 9 (permalink) Old Sep 25th, 10, 08:56 PM
Jason
blue89bird's Avatar
does anybody still have this picture? I know it's old but have to drill it soon.
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
post #9 of 9 (permalink) Old Sep 25th, 10, 10:27 PM
Larry
larryh56's Avatar
Here's mine
Name:	Backup gromet.JPG
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
