Right front turn signal problem - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 4th, 06, 07:13 PM Thread Starter
Cool Right front turn signal problem
Hello, New member. On a friend's 2001 Camaro, right front turn signal lamp does not light. Bulb is good, wiring is good but no power to socket. Rear right bulb lights but does not flash when turn signal activated. Turn signal switch or something easier. Any help would be greatly appreciated. Thanks! busman523
busman523 is offline
post #2 of 3 (permalink) Old Feb 5th, 06, 12:53 AM
Re: Right front turn signal problem
First of all, Welcome to Team Camaro!!! It sounds like you might have a faulty ground wire or the socket contacts might be dirty. Also trace the wire to the connector on the harness and check for power with a test light. It might be as simple as a loose connection somewhere along the line. Does the left hand turn signal work? Maybe a possible flasher problem?
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 3 (permalink) Old Feb 5th, 06, 10:40 AM Thread Starter
Left turn signal, front and rear work fine. Thanks for the help.
