69 Camaro console gauge harness question? - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 6th, 06, 02:47 PM Thread Starter
ENP
I bought a new factory fit harness for my console gauges. I have all the gauges hooked up but there is one black ground wire that needs to be grounded. Does it matter which gauge I ground it to. I hope this made sense.
ENP is offline
post #2 of 5 (permalink) Old Feb 6th, 06, 02:57 PM
Re: 69 Camaro console gauge harness question?
I am sure if I am wrong somebody will set this straight, but as far as I know from my gauges, the ground goes from the gas gauge to the temp gauge.
klingrr is offline
post #3 of 5 (permalink) Old Feb 6th, 06, 03:21 PM
Ground wire in the harness attaches to the rear gauge mounting plate, dead center of the plate, there should be a hole there for a sheetmetal screw. There is a jumper wire that goes from the rear plate to the front plate. Console lights for the fuel and temp gauge won't work without the jumper.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #4 of 5 (permalink) Old Feb 6th, 06, 03:36 PM
Thanks Mark, I was thinking of the jumper wire not the direct ground (brain cramp).
klingrr is offline
post #5 of 5 (permalink) Old Feb 6th, 06, 06:53 PM Thread Starter
ENP
Mark, I sent you a pic of my harness and gauges. I am still confused where the black ground wire goes.
ENP is offline
