Power antenna - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 9th, 06, 12:31 PM Thread Starter
Eric
Power antenna
Has anybody put a power antenna on a first gen? I want to be able to run it down flush with the top of the fender so the cover does not have to have a hole in it. So.... What kind did you use? Did you have any problems doing it? Anything I should know first?
ERIC
67 Convertible, 350CID, TKO600RR, 3.73 Eaton Posi
ept000 is offline
post #2 of 2 (permalink) Old Feb 10th, 06, 07:03 AM
Randy
rs1968ss's Avatar
Re: Power antenna
I used one on my 68 but it is in the rear not on the front fender. I just used one from AutoZone (or similar). Ran the power to a rocker switch since my radio does nto have the feed for it. I did it so that I could use a car cover without cutting the hole. Very easy to install.
-Randy
rs1968ss is offline
