Wiper dosent shut off... - Team Camaro Tech
post #1 of 12 (permalink) Old Feb 10th, 06, 07:37 PM Thread Starter
Not that I will ever use the wipers here in arizona (it hasnt rained here since October 18th 2005)...
When I bought the car, they had rigged up a switch on and off for the wipers, so I bought a new switch and I have a new engine compartment wire harness, and going from lower right to upper left, I have the black wire, blue wire and yellow wires connected...it will go from high to low but does not turn off even in the off position. In searching the other posts I read that there should be a ground wire from one of the screws on the motor to ground...I tried this and still they wont go off. They turn on and off with the ignition key fine...anyone have any ideas of what could be wrong?
Liveinaz is offline
post #2 of 12 (permalink) Old Feb 10th, 06, 08:11 PM
Re: Wiper dosent shut off...
There should be another light blue wire coming from the engine harness to the wiper terminal board. Is it there? Does it look like the wiper terminal board has been rewired? It might be wired wrong. Check the wiper motor and see if the original rivets are there on the terminal board.......Just a hunch on what the problem might be.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 12 (permalink) Old Feb 10th, 06, 08:15 PM Thread Starter
I dont have the washer portion, but the clip or connector has a blue wire and two yellow wires on one connector, and the other connector has a blue and yellow wire, but that connector does not fit the terminals so I would assume that is for the washer motor...there is also a single black wire that has a connector. so basically there are only 3 terminals on the motor...unless there is one that I cant see...
Liveinaz is offline
post #4 of 12 (permalink) Old Feb 10th, 06, 09:24 PM
wdf
should be 3 wires to the wiper itself- single black ground wire and a two wire connector (the other two wire connector goes to the washer but has different spacing than the wiper connection) if your switch is ok then the usual cause is the park interuptur switch in the wiper itself.
wdf is offline
post #5 of 12 (permalink) Old Feb 10th, 06, 09:28 PM
Your wiring sounds right. There is a "Park switch" inside the wiper motor that actually shuts it off when it reaches the park position, i think it's bad.
post #6 of 12 (permalink) Old Feb 10th, 06, 09:47 PM
I double checked my wiper terminal board. From left to right......Black single ground wire, light blue wire, yellow wire which goes to the washer unit. Looks correct. It must be an internal problem with the wiper motor.
post #7 of 12 (permalink) Old Feb 11th, 06, 04:57 AM Thread Starter
Is there a way to fix the "park switch" inside the motor, or do I just need to buy another motor? If I have to buy a new one, where is the best place to get this? are there aftermarket motors available? Thanks..
Liveinaz is offline
post #8 of 12 (permalink) Old Feb 11th, 06, 05:09 AM
Tony
I had the same issue a few months ago, Did the add on switch deal temporarily until I cot a new motor. I went to NAPA and the had one in stock, cost something like $28-$30. Fixed the problem works great now.
Tony:
67 RS Clone, 388 SBC/Keisler TKO 600/12 bolt, 3.90 gear w/posi and a 250 shot of N2O for fun. See my progress at: password is camaro
idoxlr8 is offline
post #9 of 12 (permalink) Old Feb 11th, 06, 05:13 AM Thread Starter
you got the complete motor for $30? or just the internal park switch? If internal switch, was it difficult to replace?
Liveinaz is offline
post #10 of 12 (permalink) Old Feb 11th, 06, 05:15 AM
you can get them from a repor house for $79 or any auto parts store for $50. Make sure you ask for the right year, 67 is different. I need a pic of the back side for the elelctrical sticky,need to show whay a 67 is different.
post #11 of 12 (permalink) Old Feb 11th, 06, 05:22 AM
Tony
It was the whole wiper motor (no washer pump).
Tony:
idoxlr8 is offline
post #12 of 12 (permalink) Old Feb 11th, 06, 11:53 AM
As a reminder, you might want to replace the wiper to firewall seal and a new set of wiper grommets, if the new motor doesn't come with them.
