key buzzer - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 14th, 06, 04:58 AM Thread Starter
key buzzer
I am trying to get my key buzzer to work. I have replaced door jam switches. I have replaced horn relay. It is still not working. Can anyone tell me what else I can check? Someone mentioned contactors in the steering column, but not sure where they are located. Any help would be appreciated. Thanks!
cajunbaby100 is offline
post #2 of 10 (permalink) Old Feb 14th, 06, 05:34 AM
Re: key buzzer
The following link is to a key warning buzzer diagnosis scan for a generic GM steering column. So even though it is posted on the Corvette websight, it is valid for Camaros as well.
http://jimshea.corvettefaq.com/wp-co...rDiagnosis.doc
JIML82
JIML82 is offline
post #3 of 10 (permalink) Old Feb 14th, 06, 09:17 AM Thread Starter
Re: key buzzer
i can not get into that file
post #4 of 10 (permalink) Old Feb 14th, 06, 10:16 AM
Wes
Re: key buzzer
On a 69, the actual buzzer is near the voltage regulator. I'll check when I get home, but I believe it's a smaller guage pink wire with a black stripe,..that comes from your starter switch.
Check to see if it's connected. Sometimes it's disconnected.
Straight-line-69 is offline
post #5 of 10 (permalink) Old Feb 14th, 06, 10:23 AM
Re: key buzzer
I opened it and converted to PDF. PM me your email address and I'll send it to you. It's about 1Mb.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #6 of 10 (permalink) Old Feb 14th, 06, 10:47 AM
Charles
Re: key buzzer
here is the contact inside the column. it has two small copper tangs inside a plastic "cartridge". the whole thing will just pull right out. the plastic "cartridge" will get old and break or the copper contacts will get bent or dirty and not make contact. it is located under the turn signal housing.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #7 of 10 (permalink) Old Jun 10th, 14, 06:47 PM
Re: key buzzer
My car is coming off of a fresh restoration. I'm finishing up with the interior and need some help on the key buzzer. My buzzer did not work and I noticed the tangs on the "cartridge" were bent. I figured that was the issue so I started straightening them out. I now see that that was a mistake. Can somebody tell me if the two contacts are supposed to touch each other and what are they supposed to touch?
scsdz302 is offline
post #8 of 10 (permalink) Old Jun 10th, 14, 07:13 PM
Jack
Re: key buzzer
Just did this project myself. I ended up with two problems 1) The "cartridge" as its been referred to was all bent up so I replaced it. Like someone else mentioned it just slides in and 2) My horn relay either didnt work as a buzzer or never did so I had to replace it. I found that getting it to work first at the relay and then moving on to the steering column was helpful.
69 Z28 x77 Hugger Orange / Deluxe Houndstooth / M21 / 4:10 posi / Canadian Docs
Jack92584 is offline
post #9 of 10 (permalink) Old Jun 10th, 14, 07:24 PM
Re: key buzzer
The buzzer works. The problem is I can't get it to stop buzzing or if I move the tabs it won't buzz at all. I can't figure out what is supposed to touch and what isn't.
scsdz302 is offline
post #10 of 10 (permalink) Old Jun 10th, 14, 07:24 PM
Jack
Re: key buzzer
Heres a photo of a new one showing the relationship of the tangs to each other
http://www.camarocentral.com/product_p/das-1014.htm
