One wire Altenator? - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 15th, 06, 12:40 PM Thread Starter
Berry
One wire Altenator?
I got a question about a Powermaster 1 wire altenator. I was thinking about replacing my altenator for a Powermaster 1 wire altenator and was wondering exactly how to hook it up. Currently I have a regular stock altenator hooked up with the 3 wires (2 that go into a clip on the back of the altenator and a red one by itself). basically my question is if I wanted to go the 1 wire route I know you go straight from the battery to the altenator, but which of the 3 wires goes to the other post on the altenator? or should I go with all 3 wires instead of the 1 wire any advantages/disadvantages? what and where are the 3 wires for and go??
BERRY251 is offline
post #2 of 5 (permalink) Old Feb 15th, 06, 01:06 PM
Re: One wire Altenator?
A 1-wire alternator is very simple to hook up. The large red wire goes on the stud on the back of the alternator and that's it. The other two wires are not used. The down side is you will lose your ALT or GEN light function on the dash. If you have a volt meter or gauge in the car you'll just have to rely on it to see if it's charging. If the Powermaster has an output of 100 amps or more you should upgrade the large red wire to at least 8 gauge.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 5 (permalink) Old Feb 15th, 06, 01:18 PM Thread Starter
Berry
thanks for the info I knew it was easy, you wouldnt happen to know which wire on the original setup goes to the light in the dash do you?
BERRY251 is offline
post #4 of 5 (permalink) Old Feb 15th, 06, 04:31 PM
brown? maybe... do a search here your answer and you will find your answer
but why do you want to know?
400bird is offline
post #5 of 5 (permalink) Old Feb 16th, 06, 07:29 AM
Guess
HwyStarJoe's Avatar
https://www.camaros.net/techref/ftecref14.html
http://www.madelectrical.com/electri...hreewire.shtml
http://www.madelectrical.com/electri...elcoremy.shtml
HwyStarJoe is offline
