Any First Generation Electrical Gurus Here? - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 16th, 06, 11:13 AM Thread Starter
On my 69 there is/was a condenser mounted to a terminal on the voltage regulator to ground. From what I've read, this was to help eliminate static on cars with factory radios/stereos. Is this necessary when a modern stereo is installed and does it have any other function? For that matter, a definition of a condenser would be great. I always thought they were just capacitors. Any input? Thanks, Joe in DFW...
jweb4747 is offline
post #2 of 6 (permalink) Old Feb 16th, 06, 12:55 PM
Re: Any First Generation Electrical Gurus Here?
You're right, they are capacitors and the one on the regulator was for static suppression. Try it without it and see what happens. Most of the static was on AM not FM and not many people listen to AM anymore.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 6 (permalink) Old Feb 16th, 06, 01:17 PM
I kept mine on strictly for looks and not function. It was needed back in the days when the original radios were AM band and is no longer needed on today's Radio/Stereos. Just make sure that all the proper ground wires are in place from the radio and also the body to frame ground located on the passenger frame rail.
Camaro buds until the end!!!
Camaro Dave is offline
post #4 of 6 (permalink) Old Feb 16th, 06, 06:15 PM
I kept mine as well, it "looks" more correct that way. The relays in an old style regulator can hit some pretty hard surges tho. If you use a wells vr715 electronic regulator you don't need the capacitor.
fyi... a capacitor presents an OPEN circuit to direct current (the cars 12 volts) but presents a short to alternating current. It shorts the big spikes when the relay's open and close to ground. (grossly oversimplified so don't call me on the details!) preventing them from interfering with the radio.
post #5 of 6 (permalink) Old Feb 17th, 06, 07:54 AM Thread Starter
I just added the 715 regulator and was surprised it had the tab for the condensor. I will add one if I can find it. I looked yesterday at the local shops but they all had the adjustable band with small mounting hole. There would be no way to mount it to the quarter inch reg. bolt correctly. Anyone know where to find one that will work? Thanks
jweb4747 is offline
post #6 of 6 (permalink) Old Feb 17th, 06, 08:03 AM Thread Starter
While I have your attention, there's a red 10ga wire coming out of my bulkhead connector that I didn't hook up years ago and now it's bugging me. I thought it was for main dash bus because it is hot with the ignition on but that can't be right because when I hook it to 12v+ with the key off it energizes the ignition. Maybe that's why I left it unhooked?
jweb4747 is offline
