67 fuse block wiring troubles - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 17th, 06, 01:16 PM Thread Starter
I recently put the motor back in my 67. And I didn't mark the wires on the engine wiring harness. I have power to the starter from the battery, but no power into the fuse block. Is the main powering wire for the fuse block on the engine harness?
bertrane396 is offline
post #2 of 4 (permalink) Old Feb 17th, 06, 01:35 PM
Paul
Re: 67 fuse block wiring troubles
There is a foot or so long wire that goes from the positive terminal to a junction block just behind the battery - It is mounted to the radiator support.
This wire needs to also be tied into the battery and energizes your fusebox.
oakster is offline
post #3 of 4 (permalink) Old Feb 17th, 06, 06:06 PM
Check the "what is is, where it is" sticky, 'bout the only thing that's done is pics of the wiring on the rad support.
post #4 of 4 (permalink) Old Feb 17th, 06, 09:52 PM
NO.....You will need to buy a front end harness or use your old one, depending on what you want to do. The front end harness controls your head lights as well as feeds power to the fuse box.
Camaro buds until the end!!!
Camaro Dave is offline
