electric fuel pump - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 19th, 06, 03:49 PM Thread Starter
electric fuel pump
my 91 came with a 305 tbi and it now has a 350 that was swapped before a bought it. is there anyway that i can still use the fuel pump from the 305 on the 350 because i have a mechanical fuel pump on the 350 but id like to put an electric fuel pump in and was wondering if the stock pump electric fuel pump that came with the car would work with the 350.
350camarokid is offline
post #2 of 7 (permalink) Old Feb 19th, 06, 09:32 PM
Re: electric fuel pump
Chances are that it will, since the pump doesn't care what size the engine is.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 7 (permalink) Old Feb 20th, 06, 07:28 AM Thread Starter
what would i need to do to hook it up to my engine
post #4 of 7 (permalink) Old Feb 20th, 06, 07:48 AM
If your original engine had THROTTLE BODY INJECTION, you can use your existing in tank electric pump, but you will need a BYPASS style regulator, set to deliver 6 psi to the carb.
If it had TPI, this won't work, the pump pressure is too high.
post #5 of 7 (permalink) Old Feb 20th, 06, 08:52 AM Thread Starter
it was TBI so i should be good for what you told me to do. where can i get the regulater and who makes it?
post #6 of 7 (permalink) Old Feb 20th, 06, 08:56 AM Thread Starter
let me check my vin number to be sure
post #7 of 7 (permalink) Old Feb 20th, 06, 08:58 AM Thread Starter
i was wrong the car originally came with TPI so is there any other way to make it run off the stock fuel pump?
