Turn signal Socket for a 68 - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 20th, 06, 04:06 PM Thread Starter
I am installing a turn signal socket in my 69 camaro. I am having trouble getting the second filament (the brake light) to come on. The car came with the wiring and socket for only the drivers side. On this side, both filaments light when the head lights are on and I hit the brakes. On the the other side, there are two hot wires. With my test light i identified the running light wire and the brake wire. howerever, the brake light filament does not come on. i tried it in the good socket and it works, i also tried rotating the build but nothing. only the dim filament comes on.
i am not sure if i am grounding this correctly. i assume one wire is is for the brake lights and the other is for the running lights. is this the correct socket? how do i ground it?
any other suggestions are appreciated. b/t/w, i assume this socket also handles the turn signals, but none of the signals work so that is a project for another day
thanks
The part number is 85865 made by conduct tite. the link is below.
http://www.dormanproducts.com/cgi-bi...LL&vTime=68351
rodutah is offline
post #2 of 3 (permalink) Old Feb 20th, 06, 07:57 PM
Re: Turn signal Socket for a 68
The socket grounds thru it's mounting. There are 2 lil metal things on the lip that goes into the tailight, that's the ground.
Without a proper ground, you're beating a dead horse. The tail lights housings have to be bolted to the body (I use star washers under 2 of the nuts to make sure) and the back of the housing where the bulb plugs in needs to be clean.
post #3 of 3 (permalink) Old Feb 21st, 06, 05:35 AM Thread Starter
Thanks Jim much appreciated
rodutah is offline
