where does the harness run? - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 23rd, 06, 05:44 PM Thread Starter
I am running new harnesses under the hood. Where does the headlamp harness run around the radiator support? Under it or over the top? The old harness was butchered and I'm not sure where it was supposed to go. Thanks
68 RS 302 is offline
post #2 of 5 (permalink) Old Feb 23rd, 06, 05:55 PM
Brad
Re: where does the harness run?
It goes under the top rail of the support.
Most recent 01/01/10
spideynut is offline
post #3 of 5 (permalink) Old Feb 23rd, 06, 06:28 PM Thread Starter
Sorry I forgot to mention it was for my 68 RS. What point on the radiator support does the wiring run through to get the the front side of it in order to go under the rail? Does it go around the radiator support on the drivers side behind the headlamp? Thanks.
post #4 of 5 (permalink) Old Feb 23rd, 06, 10:29 PM
Yes......the front light harness goes from underneath the driver's side fender to the radiator support front lip, behind the headlight.
Camaro buds until the end!!!
Camaro Dave is offline
post #5 of 5 (permalink) Old Feb 24th, 06, 07:51 AM
click's Avatar
The harness and vac hoses for the headlight doors all tuck up into the notch at the top of the rad support. You can see the green horn wires in this pic that come out of the harness thats tucked up there. Does this help? If not, I might have to look for more pics I might have later.
click is offline
