77 camaro distributor setting - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 24th, 06, 03:42 PM Thread Starter
Question 77 camaro distributor setting
I'm trying to set the timing in my 77 camaro. Think I ma pretty close, but would like some advice. When I crank the engine I get kind of like a back fire out of the exhaust. Am I pretty close to being on time to start or am I way off.
xerxe8 is offline
post #2 of 2 (permalink) Old Feb 25th, 06, 08:14 PM
Re: 77 camaro distributor setting
Back off your distributor. Turn it CCW a bit. Once you get it started, recheck the timing. If you have the 350 motor, the timing should be around 6-8 degs. BTDC.
Camaro buds until the end!!!
Camaro Dave is offline
