HEI Coil Replacement - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 3rd, 06, 09:07 AM Thread Starter
My in-cap coil on my GM HEI distributor needs to be replaced, as the (+) lead melted and shorted out against metal of the coil. I orginally thought there was a problem with my MSD (6al) box because I wasn't getting a spark, however, this seems like a much more likely culprit. Should I replace this coil with an OEM coil or an aftermarket coil? Is an external coil the way to go instead---and if so how would it be installed. My gut feeling is to get another in-cap coil. Thanks all....
NRMEDIC984 is offline
post #2 of 10 (permalink) Old Mar 3rd, 06, 09:17 AM
Re: HEI Coil Replacement
IMO, if you have an MSD box, install an MSD coil.
post #3 of 10 (permalink) Old Mar 3rd, 06, 11:16 AM Thread Starter
Ok, for the price I ordered the internal type MSD coil. Hopefully this solves my problem. Thanks again.
post #4 of 10 (permalink) Old Mar 3rd, 06, 01:52 PM
Matt Jones
If you can, try to get an external coil. These are usually oil filled and are able to maintain a much cooler temperature. HEI coils get way, way too hot; and I would think it would be worse with an MSD box.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #5 of 10 (permalink) Old Mar 3rd, 06, 05:49 PM
I'm with Silver - oil fillled is the way to go. In fact, when mounting an oil filled coil you should mount it according to the directions which is usually in the vertical direction. I have a www.davessmallbodyhei.com HEI distributor in mine that uses an accell super coil at Dave's recomendation.
dnult is offline
post #6 of 10 (permalink) Old Mar 6th, 06, 06:09 PM Thread Starter
My new MSD coil is installed with no problems. I still have no spark. The troubleshooting tests yield no results. My heavy black lead (ground) for the MSD box is getting a constant 12 volts....does this sound normal??? I think the box got fried when the coil shorted out. What do you guys think?? Thanks
post #7 of 10 (permalink) Old Mar 7th, 06, 03:33 AM
The box may have gotten fried. Bypass it and see if the engine starts up.
post #8 of 10 (permalink) Old Mar 7th, 06, 08:10 AM Thread Starter
Thanks I'll give that a try tonight. I wasnt sure if that was ok to do because the 4 pin module was removed when the 6AL was installed. Thanks again.
post #9 of 10 (permalink) Old Mar 8th, 06, 08:14 AM Thread Starter
post #10 of 10 (permalink) Old Mar 8th, 06, 08:38 AM
Nice forum.
