JimM - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 4th, 06, 06:22 AM Thread Starter
JimM
How about a section on relays, the type used with electric fans, what goes where.
Proper wire size for intended voltage/amps.
I know you're busy but some just "need to know" before Murphy finds them.
68 Camaro~LSx ~all motor
post #2 of 4 (permalink) Old Mar 4th, 06, 06:35 AM
Re: JimM
for sure some good things to put on the list! tx doug
post #3 of 4 (permalink) Old Mar 4th, 06, 07:27 AM
Rod
Re: JimM
Just do a search on Google, while its great that Jim wants to put all the Basic Electrical information together it is widely available on the net. I think it would be better to focus on 1st gen specific components with links to other sites for Electrical Basics information.
Rod
69 Camaro with LS2/4l70e
Rocketrod is offline
post #4 of 4 (permalink) Old Mar 4th, 06, 11:33 AM
Re: JimM
Proper wire sizes is a tricky topic. At least as far as any official rating of "use this size wire for this much current" does not exist. Wire is rated in resistance per foot. And knowing how much resistance you can tolerate is just a small part of the equation. You need to know the maximum voltage drop you can afford to see and the maximum power you can expect the wire to dissapate.
I did find a chart that lists the temperature rise per amp of several wire sizes. I think it's a pretty good guide if you consider the maximum temperature rise you'd expect the wire to see. I'll try and locate it. It works pretty well if you consider the load current, length of the run and other basic aspects of the circuit.
dnult is offline
