Power Window Motor Connectors - Team Camaro Tech
post #1 of 12 (permalink) Old Mar 5th, 06, 02:40 PM Thread Starter
Does anyone know where I can get the round hard plastic replacement plug connectors for the '67 power window motors? Two of mine are so brittle they crumbled in my fingers when trying to plug the harness back in. The rest of the harness is in very good condition.
Thanks,
Hammered is offline
post #2 of 12 (permalink) Old Mar 5th, 06, 02:46 PM
Charles
Re: Power Window Motor Connectors
can you post a pic of the needed connector? or email it to me?
i replaced my 69 harness with all new and i still have the original but butchered up harness. the connectors may or may not be correct for 67.
if they will work i'll butcher mine up a little more for you.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #3 of 12 (permalink) Old Mar 6th, 06, 08:52 AM Thread Starter
Run269,
Thank you for the offer. I am out of town, but will try to get you a picture late tomorrow or Wednesday. Mine are green in color, are round and have two female spade sockets oriented in a T fashion.
Hammered is offline
post #4 of 12 (permalink) Old Mar 6th, 06, 09:06 AM
Charles
ok john,
i'll look at my harness and see if mine fit your description.
Run269 is offline
post #5 of 12 (permalink) Old Mar 15th, 06, 06:36 PM Thread Starter
Run269,
Sorry I didn't get this posted sooner, but I'm still interested. Here is a pic of the connector I'm looking for:
http://i37.photobucket.com/albums/e1...PwrWinConn.jpg
Hammered is offline
post #6 of 12 (permalink) Old Mar 15th, 06, 08:30 PM
Charles
mine are white and look different. i'll see if i can get a pic up tomorrow for you. they might interchange. biggest difference i see right off is mine have 2 ears with locking tabs on them. maybe yours are broken off.
Run269 is offline
post #7 of 12 (permalink) Old Mar 16th, 06, 02:44 PM Thread Starter
I think you've got the later style. Mine have to slide into a round receiver and there is a clip broken off, but it does not sound like yours. A picture will tell for sure.
Thanks,
Hammered is offline
post #8 of 12 (permalink) Old Mar 16th, 06, 03:01 PM
Charles
here's what i have,
Run269 is offline
post #9 of 12 (permalink) Old Mar 16th, 06, 08:41 PM
Steps
Bit off subject...Could someone put up a pic of where the wires go from the pillar into the door for a '69 please. I assume all 1st gen would be similar.
Installing centeral locking with a new alarm.
Steptoe is offline
post #10 of 12 (permalink) Old Mar 18th, 06, 06:34 PM Thread Starter
I think those would work, but mine have a single locking tab on the side pointing toward the knuckle of your index finger. I hate to have you cut it for me without knowing for sure. Let me continue doing some checking.
Steptoe: There should be a dimple on the door jam and hinge post indicating the hole center. The factory boots use a much larger hole on the hinge post. I don't know the exact size, but if you buy the repro boots you can figure it out.
Hammered is offline
post #11 of 12 (permalink) Old Mar 18th, 06, 06:43 PM
Charles
hammered,
you might contact someone at www.americanautowire.com
they make all of the repro harnesses and might be able to hook you up. i bought a new 69 fuse box from them, and used their harnesses to redo all my power windows. you may have to sweet talk them or be persistant because of course they would rather sell you the entire harness.
Run269 is offline
post #12 of 12 (permalink) Old Mar 18th, 06, 08:29 PM
Steps
Hammered...Cool thanks..I know what im looking for now...rest will be history Nps.
Steptoe is offline
