Which battery is best? - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 6th, 06, 05:43 PM Thread Starter
Which battery do you prefer? I am thinking about an Optmia type. /any thoughts?
orange 68 is offline
post #2 of 11 (permalink) Old Mar 6th, 06, 06:20 PM
Re: Which battery is best?
Optima, hands down. I just replaced an Optima red that was 9 years old, they're worth the extra dough, my new one was about 125 dollars!!!
kz1000ltd is offline
post #3 of 11 (permalink) Old Mar 6th, 06, 07:42 PM
Rod
Optima red
Rod
69 Camaro with LS2/4l70e
Rocketrod is offline
post #4 of 11 (permalink) Old Mar 7th, 06, 05:00 AM Thread Starter
Optmia it is!!! This is what I was thinking about, but just wanted to check to see what everyone else thought. I think the Optmia will help the looks under the hood also. I am in the middlw of an engine upgrade as far as cosmetics goes and will post before and after pcitues when completed. Thanks for the input!!!!
post #5 of 11 (permalink) Old Mar 7th, 06, 05:22 AM
Tony
Optima is by far the best deal! My personnel expierence is that I had the charging wire on the back of the alt. break off and I drove 64 miles, makeing 3 stops and only then did it slow down enough to show a drain during cranking but ran all the way home. My vote is defineately an Optima!
Tony:
67 RS Clone, 388 SBC/Keisler TKO 600/12 bolt, 3.90 gear w/posi and a 250 shot of N2O for fun. See my progress at: password is camaro
idoxlr8 is offline
post #6 of 11 (permalink) Old Mar 8th, 06, 10:13 PM
When I first saw this Thread, I wanted to be different and say Interstate. I found out that Optima and Interstate are the same company. So I will say Optima.
Camaro buds until the end!!!
Camaro Dave is offline
post #7 of 11 (permalink) Old Mar 8th, 06, 10:48 PM
mike
Optima!! I love these batterys.......
nikkisdad is offline
post #8 of 11 (permalink) Old Mar 9th, 06, 11:16 AM
Wes
If you don't drive the cars much, the Optima Yellow is nice,..but either Optima is worth extra expense.
My second choice is A/C Delco.
Straight-line-69 is offline
post #9 of 11 (permalink) Old Mar 9th, 06, 01:23 PM
Craig
Brackneyc's Avatar
I had a Yellow top Optima in my Jeep for 5 years (still there, but sold now to my brother) and it was used for winching, as well as running lights and a decent stereo. Never an issue with that battery. I will likely get one for the 67 when the time comes.
Craig
Now you will see that evil will triumph, because good is dumb.
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Brackneyc is offline
post #10 of 11 (permalink) Old Mar 9th, 06, 04:50 PM
Lonnie
I'm ready to buy a battery, also. What are you guys using to hold down the Optima batteries? Can you use the factory clamp at the base of the battery? thanks
68 Camaro,327, vortec heads, Comp Cams XE274,Muncie M-20, 8.5 rearend, 3.73s. My 1st love,owned since 76'
lowrida is offline
post #11 of 11 (permalink) Old Mar 10th, 06, 05:02 PM
Rene
rsbecool's Avatar
Optima red is what I use. I took the clamp supplied by optima and turned it up side down and used a longer bolt to screw into the factory battery tray.
68 rs 350
M-20 4-speed
10 bolt 8.5 3.23
TC #24
rsbecool is offline
