Temp counsol gauge - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 7th, 06, 01:46 PM Thread Starter
Billy
Temp counsol gauge
I have a '69 w/ the gauges on the counsol. It works just a little when the engine comes up to temp.Only registers about 1/8 of the way.Is it a problem w/ the gauge or the sending unit ?
What should it read at normal temp?
Thanx
Billy
1969 RS/SS - 350/300 - Rallye Green / Black Vinyl Top
Camaro Billy is offline
post #2 of 7 (permalink) Old Mar 7th, 06, 03:19 PM
Re: Temp counsol gauge
Depending on the air temperature, you should pointing one side or the other of center. That's assuming the guage is calibrated correctly. You also need to have a sending unit for a guages car. NAPA has them. Hope this helps.
nashcar is offline
post #3 of 7 (permalink) Old Mar 7th, 06, 04:51 PM
JohnZ's Avatar
Thanx
Billy
You can't tell without shooting the radiator hose just above the thermostat housing with an I.R. gun so you know what the REAL temp is, then correlate that to the gauge indication. My '69Z console temp gauge needle sits at 1/4-scale, and my I.R. gun shows that's 175*.
JohnZ
CRG
JohnZ is offline
post #4 of 7 (permalink) Old Mar 7th, 06, 07:16 PM
click's Avatar
My 69 LM1 (350/255) runs one tick above the 1/4 mark on the guage and my I.R. gun shows 180* which must be open Tstat since that is the stat I have. With my A/C on going uphill or in heavy traffic with A/C on, the guage reads slowly up to top center but rarely goes over that and comes right down when I turn off the A/C or cruise faster.
click is offline
post #5 of 7 (permalink) Old Mar 8th, 06, 03:46 AM Thread Starter
Billy
What can I do to try and fix it ? Should I replace the sending unit?
Somebody said something about calibrating the gauge, how do I do that?
Thanx
Billy
post #6 of 7 (permalink) Old Mar 8th, 06, 05:59 AM
Thumbs up Re: Temp counsol gauge
Thanx
Billy
According to the instructions from the guy at Rick's you get the car at operating temperature, make sure of the temp with an ir gun, and carefully lift off the needle on the gauge. Then you CAREFULLY put the needle back on at the mark John Z said. I had the same problem last year after I made sure of the correct sender and the wires were good. After I cailberated the gauge, it has worked perfectly.
Hope this helps.
klingrr is offline
post #7 of 7 (permalink) Old Mar 8th, 06, 09:37 AM Thread Starter
Billy
Any way to test the sending unit to make sure it's good ?
Could this problem be the sending unit ?
I hate to replace it if I don't need to.
Billy
