underdash harness question - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 7th, 06, 03:50 PM Thread Starter
Joe
Is there a way to convert my underdash harness to an underdash harness for console gauges and tach? I'm putting gauges in my 67 and I would like to avoid spending $350 dollars (Rick's catalog) on a new harness. Especially since I have to buy 3 other harnesses for the gauges and console yet.
Eighttrakz is offline
post #2 of 7 (permalink) Old Mar 7th, 06, 04:31 PM
Paul
Re: underdash harness question
There is a conversion harness you can buy. It requires a bit of work to wire it into the existing harness. You need to splice in a lot of wires. Someone tried this on my car before I got it and they ended up butchering everything to the point that I ended up replacing all the harnesses. I got the instructions with my car for the kit and can fax them to you if you want to shoot me a pm. The issue wan't the kit so much as the person who tried to do the install.
I used Factory Fit wiring and everything worked perfectly. You may want to contact them at www.factoryfit.com They were the guys that make the conversion kit.
In terms of the tachometer, I believe the curcuit board on the guage cluster is the same with or without a tach. All you need to do is swap in a factory tach and you're good to go.
Paul
oakster is offline
post #3 of 7 (permalink) Old Mar 7th, 06, 04:34 PM
Paul
I actually just downloaded their catalog and the conversion is $93.00. They are different for manual trans vs auto and if the shift is on the column or the console. Check out page 9 of their catalog
http://www.americanautowire.com/imag...0Harnesses.pdf
oakster is offline
post #4 of 7 (permalink) Old Mar 7th, 06, 05:47 PM Thread Starter
Joe
That fax would help a lot. I'll send a message with the number.
post #5 of 7 (permalink) Old Mar 8th, 06, 05:14 AM
AAW
Hi. We just got our new Factory Fit Catalogs in. If you want one - go to our website and click the "request catalog" button at the bottom of each page.
Or, like mentioned above - you can download it onto your computer from our website, too.
Either way, I'd be happy to help.
~Theresa Antell~
American Autowire / Factory Fit
Ray Walder
Sales, American Autowire
Shop our online store @
Tech Questions?
AAW is offline
post #6 of 7 (permalink) Old Mar 8th, 06, 11:00 AM
Paul
Eighttrakz - Fax sent
Theresa - I'm going to order one of your catalogs too. Just finishing up my 67 Camaro RS and starting a 71 Lemans Sport. Your wiring and support is top notch!!
Paul
oakster is offline
post #7 of 7 (permalink) Old Mar 8th, 06, 12:43 PM
AAW
Paul
Thanks, Paul!
~Theresa~
Ray Walder
Tech Questions?
AAW is offline
