battery gauge - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 8th, 06, 08:15 PM Thread Starter
Adam
battery gauge
My 68 batt gauge barely moves up or down, but it does move slightly. I'm just wondering how much it should be moving or is this normal. Please let me know what your gauges read.
autopilot70 is offline
post #2 of 3 (permalink) Old Mar 18th, 06, 12:32 PM
Re: battery gauge
The gauge should stay around the center mark, with a low battery it will move to the charge side till the battery charges, with the car off, turn on the highbeams, it should move to the discharge side. If its ever on the discharge side with the car running, you are just running off the battery.
Greg U
undee72Z is offline
post #3 of 3 (permalink) Old Mar 18th, 06, 01:10 PM
Re: battery gauge
If in doubt the gauge is working correctly, check your Alternator's output with a volt meter at the battery. Start the car and check the output, it should be around 13.5 to 14.5 volts. Then look at what your battery gauge is reading and see if it is close to what the volt meter reading was. It should be reading to the right of the center line if you have the factory gauge.
Camaro buds until the end!!!
Camaro Dave is offline
