Junction box - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 10th, 06, 08:04 AM Thread Starter
Weston
Westonz28's Avatar
Junction box
Is the junction box behind the battery needed to wire the front wire harness. What is it's function? This is for a 1968 Camaro with a V8. Thank you.
1967 RS L30/M20 2nd owner numbers matching
1968 Z28 Butternut Yellow original BU rear end
1968 SS/BB 396, Daughters Camaro BB not numbers matching.
1968 Coupe 2nd owner Sons Camaro numbers matching
1969 RS LM1 2nd owner numbers matching
1966 Chevy II SB 400 alum trick flow heads, Turbo 400, Dana 44 rear
1970 Camaro coupe, 350 L65, 350 auto, numbers matching,
1968 Chevelle Malibu, 327 L30, 3 speed on the tree, third owner.
1941 Ford Super Deluxe Coupe
1968 SS El Camino BB
Westonz28 is offline
post #2 of 5 (permalink) Old Mar 10th, 06, 08:20 AM
Re: Junction box
That junction block supplies power to the entire car, except the starter, details here: http://home.comcast.net/~Jimragtop/W...tion_block.htm
post #3 of 5 (permalink) Old Mar 10th, 06, 08:24 AM
Re: Junction box
It provides a connection point with the wire from the horn relay buss bar on the driver side of the radiator support and the positive post of the battery.
This path allows power to transfer from the positive post of the battery to the rest of the vehicle, providing the ground cable is hooked up to the negative post.
post #4 of 5 (permalink) Old Mar 10th, 06, 11:44 AM
Steps
Re: Junction box
I had a problem here some 25 yrs ago....
The wire from the battery has to be of a certain size (maybe length? cant rem) It is there so if something shorts out/overloaded or a major problem arises, this section will burn out before any real damage is done to wires in the the main wiring.
Steptoe is offline
post #5 of 5 (permalink) Old Mar 10th, 06, 04:02 PM
Re: Junction box
The wire from the battery should be fuseable wire. It's typically one size smaller in diameter and of a different material so it will burn in two before the rest of the system is damaged.
Hammered is offline
