Alternator problem....... - Team Camaro Tech
post #1 of 12 (permalink) Old Mar 13th, 06, 06:32 PM Thread Starter
Chester
My voltmeter only reads 12 or less volts with my engine running. Increasing the engine rpm does not increase volt output. Up until recently the volt meter would read 14+ volts. I took the alternator to Autozone and it tested OK. Any ideas?
68 convertible, Grotto blue, 327 TH350,3.08 diff
jacket is offline
post #2 of 12 (permalink) Old Mar 13th, 06, 06:50 PM
Garry
Re: Alternator problem.......
ck the battery.....
1969 LM1 Convertible Camaro
The restoration is ON!!
Musclecar is offline
post #3 of 12 (permalink) Old Mar 13th, 06, 07:24 PM
If you have an external regulator, check for a loose connection or a bad regulator.
Camaro buds until the end!!!
Camaro Dave is offline
post #4 of 12 (permalink) Old Mar 13th, 06, 09:20 PM
David Pozzi
davidpozzi's Avatar
electronic external regulators are available now. Wells is one brand, it pluggs right in.
davidpozzi is offline
post #5 of 12 (permalink) Old Mar 14th, 06, 03:55 AM
Wells P/N VR715.
post #6 of 12 (permalink) Old Mar 14th, 06, 04:00 AM Thread Starter
Chester
Internal regulator. I'll check the battery today and post results. Thanks.
jacket is offline
post #7 of 12 (permalink) Old Mar 14th, 06, 05:15 AM
is your gen light on?
I would check the connections and the voltages at the small connector on the alternator, and also at whatever bypass wiring was done by the original regulator location
post #8 of 12 (permalink) Old Mar 14th, 06, 06:34 PM Thread Starter
Chester
I tested the battery, it's good. Re-tested the alternator on the car and it was only putting out high 11 low 12 volts. I have changed the alternator and now I'm getting 13 volts at idle and 14 at cruise speed. The wiring system is American Auto Wire Classic Update series. This would be similar to a Painless system specifically for a 68 Camaro. The alternator is a internal regulated 68amp for a 78 Camaro. Ignition system HEI. Am I OK with this set up and voltage output?
jacket is offline
post #9 of 12 (permalink) Old Mar 14th, 06, 07:10 PM
yes, sounds like you're good to go now. So much for whatever they use to test em with at autozone
post #10 of 12 (permalink) Old Mar 14th, 06, 07:21 PM
Steven
Sometimes where you take the measurement makes a difference. You may see one voltage measuring at the battery, but see a slight drop inside the car... Measure at the battery to be sure ... Otherwise, when you run accessories like A/C and maybe lights together, you may be borderline with dimming lights ...Also, using something a little more specific like a multi-meter, you may see that your 13volts is actually 13.5 or so, and likewise for your 14 upper end ... it may be as high as 14.5 or so ... So, probably you are ok, but, I would measure at the battery for alittle peace of mind. Also, make sure that your alternator belt is properly tensioned. belts can slip without squealing, so double check it ....
sdtsdt is offline
post #11 of 12 (permalink) Old Mar 14th, 06, 09:29 PM
Dealt with a similar situation on a car. Ended up being the connector in the harness at the altenator that was hidden under shrink wrap. So now I always check connectors for loose, broken wires and corrosion. Pete
67 Camaro conv, 70 Chevelle, 78 Corvette, 97 Grand Prix, 00 Grand Prix
Pete Mag is offline
post #12 of 12 (permalink) Old Mar 15th, 06, 04:19 AM Thread Starter
Chester
In fairness to Autozone, I went back and had the alt checked on the car at the battery and it showed low voltage. They replaced the alternator and gave me full refund on the old one.
jacket is offline
