1967 Tach Adjustment - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 15th, 06, 11:08 AM Thread Starter
Hi: I am just curious if anyone has ever adjusted their tach in the instrument cluster. I have a OER replacement tach that I just installed & it seems to be a few RPM's (about 50 to 70) low. Has anyone ever tweaked the adjustment before? Any ideas? Thanks in advance, Todd
tj1930vik is offline
post #2 of 11 (permalink) Old Mar 15th, 06, 11:19 AM
Re: 1967 Tach Adjustment
I have an oer 68 tictoc tach. not sure how accurate it is. It does have what looks like an adjustment screw on it's pcb. I've not dared to turn it. Let me know what happens if you do?
post #3 of 11 (permalink) Old Mar 15th, 06, 02:28 PM Thread Starter
I haven't wanted to "tweak the tach" yet, either, until I hear if anyone else has had some luck.
post #4 of 11 (permalink) Old Mar 15th, 06, 05:30 PM
someone posted briefly about adjusting a tach once, Farm Boy I think. Iaksed for details but they never appeared
post #5 of 11 (permalink) Old Mar 16th, 06, 08:02 AM
I'm interested also if anyone knows how.
Dave69Z is offline
post #6 of 11 (permalink) Old Mar 16th, 06, 08:22 AM
Farm Boy's Avatar
These old tachometers have a calibration potentiometer on the circuit board that can be accessed through a hole in the back of the tach. If you remove the tach like I did you will need to hook up two wires and ground the unit. Be sure to use a plastic screwdriver to make the adjustment to avoid shorting out the circuits inside the tach. You can get a small plastic screwdriver at Radio Shack.
Farm Boy is offline
post #7 of 11 (permalink) Old Mar 16th, 06, 10:47 AM
EXCELLENT! on my repro tictoc, the pcb is different, but the adjustment pot IS there. Now I just needa get a good reference tach, or do the math and use an osillascope (I do have one even if I don't know how to speel it!)
Anyone know how many msec's between pulses on a V8 coil wire @ 3000 rpm?
post #8 of 11 (permalink) Old Mar 16th, 06, 02:05 PM Thread Starter
I think the easiest way to spell oscilloscope is "o-scope". Works for me! A pulse count from the coil would be a great way to calibrate a tach. I think Farm Boy has a good idea about then plastic tweaker, too. Glad he mentioned it! Thanks, guys!
post #9 of 11 (permalink) Old Mar 16th, 06, 02:13 PM
Farm Boy's Avatar
My old tachometer was 50% fast before the adjustment!
I used an old analog Sun Tachometer/Dwell meter as a reference tach. I checked it out against the digital tach in my timing light and they were both identical through the entire scale.
I removed the tach from the dash. I used two jumpers to power the tach for the calibration. A third jumper for the ground would have been nice but I did not have one handy so I just grounded the tach to the shifter and made the adjustment. I adjusted it while holding the engine at 3000 RPM. The pot is sensitive so just a little movement makes a big difference. The tach is now the same as the reference tach from 600-5000 RPM.
I will repeat this warning: Use a plastic screwdriver because the tach circuit must be hot to calibrate it. This is especially important if you are making the adjustment without removing the tach from the dash. You don’t want to be blindly sticking a metal screwdriver through the adjustment hole and run the risk of shorting out your tach.
Farm Boy is offline
post #10 of 11 (permalink) Old Mar 16th, 06, 09:08 PM
Good advice above. I adjusted my tach pretty much the same way using the digital tach on my smog machine as a reference.
Be sure to check it at more than one rpm. If the reading is off by a precentage (the error is greater at a higher rpm), turning the adjustment screw is the way to go. If it is off by the same amount at all rpm's, simply remove the needle and reposition it as necessary. If you are like me, it took a little of both to get it right.
red67camaro is offline
post #11 of 11 (permalink) Old Mar 17th, 06, 05:15 AM
Does anybody know if a 69 tach is adjustable? how does the needle come off?
Dave69Z is offline
