Help with Weird Headlight problem - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 17th, 06, 06:20 AM Thread Starter
Strange thing has happened to my 68 Big Block Camaro tonite. I went for a quick cruise earlier on this evening and everything was fine. Came home and then went to take it out again about an hour later and my headlights would not come on. The strange thing is, they work OK on High Beam but nothing on low. Any advice anyone?
AussieCamaroOwner is offline
post #2 of 9 (permalink) Old Mar 17th, 06, 06:39 AM
Re: Help with Weird Headlight problem
high beam switch, remove connector, clean contacts, try it again
post #3 of 9 (permalink) Old Mar 17th, 06, 06:41 AM
click's Avatar
yep the switch on the floor next to your left foot, they get kicked, dirt and water at times from shoes, connections get messed up or pulled off completely or just a little, giving sporadic issues. Like Jim said, clean it up and try.
click is offline
post #4 of 9 (permalink) Old Mar 17th, 06, 10:28 AM
I agree, it's the Dimmer switch. I had several go bad on me. Easy to replace.....connector and two screws.
Camaro buds until the end!!!
Camaro Dave is offline
post #5 of 9 (permalink) Old Mar 18th, 06, 03:50 AM Thread Starter
I removed the switch, pulled it apart and everything looked just fine. Put the switch back together, cleaned all the contacts and tried again, no luck. Just as I was about to pull it all apart again, the lights came on and everything worked! Screwed it back into place and it's all good. Geez, I hope it doesn't black out on me as I am driving!
Once again, I appreciate everyones help and advice.
You guys rock!
post #6 of 9 (permalink) Old Mar 18th, 06, 08:08 AM
click's Avatar
for the cheap price those are, buy a new one and dont worry about it failing again.
click is offline
post #7 of 9 (permalink) Old Mar 18th, 06, 12:38 PM
Steps
Check your earths
Blowing rear light bulbs also? or blubs becomming a little discoloured.
clean the tail /brake earths.
If u are having probs up front, the rear will be due for a clean up also.
Steptoe is offline
post #8 of 9 (permalink) Old Mar 18th, 06, 12:49 PM
click's Avatar
earth = grounds for us down under impaired my sis used to live in Perth
click is offline
post #9 of 9 (permalink) Old Mar 18th, 06, 01:21 PM
Steps
AussieCamaroOwner knows what I mean lol,
A fellow Down Under (ANZAC)
Except he lives across the 'pond', a Colony of NZ.
Steptoe is offline
