No Head Lights - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 18th, 06, 05:35 PM Thread Starter
No Head Lights
The headlights on my 69 Z8 RS will not turn on. All other lights are fine. There is power to the switch. Anyone have the switch diagram so I can test it to see if the thermal breaker has failed?
Second, what should I be testing from the switch to the head lights. The lights are fine.
kenstoy1969 is offline
post #2 of 7 (permalink) Old Mar 18th, 06, 07:02 PM
Steven
Re: No Head Lights
check dimmer switch ....
sdtsdt is offline
post #3 of 7 (permalink) Old Mar 18th, 06, 08:17 PM
Pat
Re: No Head Lights
check the ground to the headlights out on the radiator support
67pat is offline
post #4 of 7 (permalink) Old Mar 19th, 06, 12:17 AM
Sean
Re: No Head Lights
2nd the dimmer switch. if you have power everywhere but at the headlights, 9 times out of 10 the dimmer switch is the culprit. I know it seems too easy.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #5 of 7 (permalink) Old Mar 19th, 06, 04:39 AM
Re: No Head Lights
Same problem here... found it was the dimmer switch on the floor.
68 Camaro~LSx ~all motor
post #6 of 7 (permalink) Old Mar 19th, 06, 09:49 AM
Larry
Re: No Head Lights
Just in case it's not the dimmer switch, here's an excerpt from my diagrams that might help you. You can find the full set in TC's classifieds.
Larry
69-er is offline
post #7 of 7 (permalink) Old Mar 19th, 06, 04:14 PM Thread Starter
Re: No Head Lights
Thanks for all the suggestions.
Turns out the issue was a dirty connection at the dimmer switch. Cleaned it up and now there is light.
We have to love working on these cars. Work on one issue and out of the blue comes another one.
Thanks everybody.
