Plug Wire Holders - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 20th, 06, 05:48 PM Thread Starter
Plug Wire Holders
Can someone recomend spark plug wire holders for center bolt valve covers.
NEED SOMETHING TO KEEP THE WIRES OFF THE HEADERS AND BLOCK.
Schoon
SCHOON is offline
post #2 of 6 (permalink) Old Mar 20th, 06, 07:17 PM
Re: Plug Wire Holders
Jegs and Summit sell a cool set of holders specially designed for those valve covers. Your looken anywere from 50-70 dollars. Just look in there catalogs or online.
70camarro is offline
post #3 of 6 (permalink) Old Mar 20th, 06, 07:19 PM
Charles
i posted a pic of my center bolt valve covers and my wire holders are plainly visible. got them both from summit.
https://www.camaros.net/forums/showthread.php?t=76926
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #4 of 6 (permalink) Old Mar 20th, 06, 08:54 PM
Lonnie
I'm using brackets and wire looms made by Smoothie. Nice aluminum brackets that bolt to the two holes on each side of head right above headers. Part # 50-82494. The looms come in different colors. Allows you to run wires along side of valve covers instead of on top so removing valve covers is a snap and you don't cover up those shiney valve covers! Picked mine up at Summit.
68 Camaro,327, vortec heads, Comp Cams XE274,Muncie M-20, 8.5 rearend, 3.73s. My 1st love,owned since 76'
lowrida is offline
post #5 of 6 (permalink) Old Mar 21st, 06, 02:00 AM
Chris
Cool Re: Plug Wire Holders
Moroso makes a set that costs $22
1967 Chevelle 496BB/TH400/Dana-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Daily Driver)
1967 C10 Short-Wide 496BB/TH400/12-bolt (The Shop Truck)
2008 Harley Davidson Dyna Low Rider
Chris @
Motorhead62 is offline
post #6 of 6 (permalink) Old Mar 23rd, 06, 05:50 AM Thread Starter
I tried the kind you have but the problem is the bolts holding on the covers are counter-sunk and not really long enough.
Schoon
SCHOON is offline
