Hybrid Alternator - Team Camaro Tech
post #1 of 1 (permalink) Old Mar 24th, 06, 06:48 PM Thread Starter
Hybrid Alternator
I have a 150 amp external Lestek regulated alt.model # 9135G. Can I use the armature from it in a Internal reg. 70 amp alternator case? It physically fits although it's a bit larger and does have more windings. Will this do anything for amperage? Or is this controlled by the internal regulator? If I do have to use the external regulated alternator and regulator, which wire goes where? The Lestek regulator has a "A" terminal Im assuming it goes to the alternator, "G" terminal for ground, "S" terminal? "F" terminal?
BDS 502 is offline
