Trouble starting 91 RS - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 27th, 06, 07:30 AM Thread Starter
Exclamation Trouble starting 91 RS
I have a 91 RS 305. I was driving and made a right hand turn and it just shut off. I noticed the fuel pump wasn't pumping so i replaced it. Still no good. So i straight wired it just to make sure it ran. It did. So i replaced the relay but still no go. The car turns over but does not start and the fuel pump does not run. I thought maybe it might be a fuse but i didn't see any blown fuses in the fuse box. Does anybody have any suggestions to what i should do?
dyepntbll6 is offline
post #2 of 7 (permalink) Old Mar 27th, 06, 12:32 PM
Re: Trouble starting 91 RS
When you turn the key to the on position, do you hear the fuel pump prime the engine at all? Is it an intermittent problem and the pump works some of the time? That will rule out the fuse or any wiring shorting out. Check for a loose connection around the tank area. Also, there is a connector just before the tank. Make sure it is tight.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 7 (permalink) Old Mar 27th, 06, 03:57 PM Thread Starter
No the pump does not work at all when i turn the key. And i checked all the connections they all seem to be connected well. But i do know that the pump is good because i straight wired it to make sure it wasn't faulty pump.
post #4 of 7 (permalink) Old Mar 28th, 06, 08:23 PM
The fuel pump fuse is not located in the fuse block at all. It is on a separate circuit and the fuse for the pump is located upside down on the inner fender well on the passenger side near the front of the car under a water tight rubber cover. If you need a pic, I'll send you one.
MwayneH is offline
post #5 of 7 (permalink) Old Mar 28th, 06, 10:49 PM
On what year did they relocate the fuel pump fuse from the under the dash fuse block? My 86 has the fuel pump fuse in the under dash box. I pull it out to bleed off the pressure in the lines when working on the system.
post #6 of 7 (permalink) Old Mar 29th, 06, 07:00 PM
Not quite sure when it was placed under the hood but my Haynes Repair manual showed me the location and there it was. I send a pic to you guys.
MwayneH is offline
post #7 of 7 (permalink) Old Mar 30th, 06, 09:42 AM Thread Starter
Thanks so much guys, all the problem was was a blown fuse. Thanks for helpin me locate it.
