Ignition Problem - Team Camaro Tech
post #1 of 12 (permalink) Old Mar 27th, 06, 09:55 PM Thread Starter
Unhappy Ignition Problem
Last week when I was tuning the carb. I was starting & stopping many times. I would say by the 5th time, when I went to start the engine, the ignition wouldn't turn over. It was like I had a bad battery, where it tries to turn over, but there isn't enough juice it cranked very slow if at all & made a weird sound. I checked the battery with a meter & it had 12 volts. Eventually changed batteries & still same problem. I had one of those high torque starters installed a year ago, so not sure if it went bad. after trying to turn the engine over for 10 minutes all of a sudden the engine turned over & fired right up. In the last 6 days since that happened I would say it has happened again twice. Just not to that extreme. When I go to start the engine it gives that momentary sound like the battery is weak, then it fires up. Battery still shows 12 volts it's about 11 volts on the gauge before the engine starts, but with the key in the on position. I checked & cleaned all the battery connections, wires & checked the plugs. All look good. Could it be the ignition switch itself it bad? Starter went bad? Maybe a bad coil? I would hate to have to change everything out one by to see if it fixes the problem. Hopefully there is some way to check these things out first.
lucky13 is offline
post #2 of 12 (permalink) Old Mar 27th, 06, 10:35 PM
Re: Ignition Problem
Sounds like timing to me. I would say it is too advanced. Try backing it off a little and see if it improves.
68 RS 302 is offline
post #3 of 12 (permalink) Old Mar 27th, 06, 11:31 PM Thread Starter
I did bump it up a little. I was having a backfire through the carb during warm up & thought the timing was a little low. I'll bring it to where it was. I didn't know too much timing would act like a weak battery during start up
lucky13 is offline
post #4 of 12 (permalink) Old Mar 28th, 06, 01:01 AM
On the timing you want to retard it if it was so far advanced to cause a starting problem (Firing through the carb). I think you have just another bad starter. They start to turn over slowly at first, then go out completely. Heat is the number one killer of starters. You didn't say what year car you have, or maybe I missed it. Starters on the 3rd Gen Camaros go out all the time, because the starters are right next to the exhaust.
Camaro buds until the end!!!
Camaro Dave is offline
post #5 of 12 (permalink) Old Mar 28th, 06, 05:08 AM
Wrap the starter with a heat shield, it will help.
post #6 of 12 (permalink) Old Mar 28th, 06, 09:06 AM Thread Starter
I have a 67 with MSD control box & coil. I will look at another starter to replace the one I have. Hopefully the starter is my problem. Occasionaly it seems there isn't enough spark to fire the engine. It has only happened a couple of times, but I had to crank & crank the engine until it would fire. It just turned over but never caught. Any good recommendations on high torque starters?
lucky13 is offline
post #7 of 12 (permalink) Old Mar 28th, 06, 09:49 AM
You might try to pump the gas pedal a couple times before cranking.
You should hook up a light to the ignition circuit to see if the system is getting crank ign voltage.
post #8 of 12 (permalink) Old Mar 28th, 06, 12:40 PM
Do you have a 12 gauge wire going to the coil at start up? You need a full 12 volts going to the coil at start up. Also, did you replace the resistor wire with a 12 gauge wire? Since you no longer have the factory points, you need a constant 12 volts going to the coil.
post #9 of 12 (permalink) Old Mar 28th, 06, 06:26 PM Thread Starter
I purchased the car with the coil already wired. I was cjecking it out last night & it is a thick wire. Not sure if it's 12 gauge though. From the starter it goes to a connector module & then from there it goes to the MSD box 7 from there a wire to the positive side of coil. I used a test light & turned the key on but no voltage. Did some searching & others have said no voltage until you turn the engine over & they also say do not hook up any test equipment o the coil. Not sure how to test it then.
lucky13 is offline
post #10 of 12 (permalink) Old Mar 28th, 06, 07:49 PM
Hummmm....... I would think that you would need 12 volts to the coil with the key in the on position. How many wires do you have connected to the positive side of the coil?
Also, it sounds like you have a 10 gauge wire which will work just as well as a 12 gauge wire.
post #11 of 12 (permalink) Old Mar 28th, 06, 08:50 PM Thread Starter
Just one wire. Still can't figure out if the problem is with the starter, coil, or ignition switch. Maybe I should just replace all 3.
lucky13 is offline
post #12 of 12 (permalink) Old Mar 29th, 06, 04:44 AM
I suggest you disconnect the MSD box from the ignition system and go back to the distributor installed in car now.
If an HEI is installed, hook the large gauge wire, full time current with ign ON, to the BAT terminal of dist.
If points dist, use a ballast resistor, then hook up to + terminal on coil with dist on - terminal.
Or borrow a distributor and substitute.
What model of dist & coil is in the car now?
