Park lamps, dash lights front side markers are on but lights are swithced off - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 28th, 06, 07:13 PM Thread Starter
on 68 non RS car. Any ideas? Thanks
68 RS Z/28
67 L78
bbd564 is offline
post #2 of 9 (permalink) Old Mar 28th, 06, 07:37 PM
Re: Park lamps, dash lights front side markers are on but lights are swithced off
Do you mean the headlights are not working? Replace the Dimmer switch.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 9 (permalink) Old Mar 28th, 06, 07:44 PM Thread Starter
Light swith is in off postion for all lights, but park lamps, front side markers and dash light are on. All other lights are out.
68 RS Z/28
67 L78
bbd564 is offline
post #4 of 9 (permalink) Old Mar 28th, 06, 07:51 PM
Hello! What happens when you turn the headlights to on??
jimi302z28s is offline
post #5 of 9 (permalink) Old Mar 28th, 06, 07:53 PM
You probably have a bad switch or the wiring is not hooked up correctly at the switch.
post #6 of 9 (permalink) Old Mar 28th, 06, 07:56 PM Thread Starter
If you turn the headlight switch on (pulled all the way out) everything is on including the park lamps. Should the park lamps go out when the headlights go on?
68 RS Z/28
67 L78
bbd564 is offline
post #7 of 9 (permalink) Old Mar 28th, 06, 08:08 PM
There was a thread about this awhile back......On certain years and models the parking lights are suppose to go out. This is what I read......I am not sure, because on my 67 they remain on when the headlights are on.
Do a search in this forum on that same problem for more answers.
post #8 of 9 (permalink) Old Mar 28th, 06, 08:21 PM
Hello, Did this just happen, or did you have the harness out of the car?? The parking lights are on with the headlights when turned on!
post #9 of 9 (permalink) Old Mar 29th, 06, 04:47 AM Thread Starter
This is new (just happened) It has to be the switch that is bad. I will check my other 68 to see if park lights go out when headlights go on. Thanks for the help on this.
68 RS Z/28
67 L78
bbd564 is offline
