Coil wire question? - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 14th, 06, 07:02 PM Thread Starter
Marc
mnm99's Avatar
Coil wire question?
I installed a MSD 6al, coil and distributer. I wired everything correctly, but have one question about the + coil wire. I had points before to let you know. There are two wires that connect to it. From what I read one is a resistor wire and one is a 12v wire from the starter...??? Can I use this to connect the switched wire that goes to the MSD box? Or can/do I have to cap them off and run a switched 12v wire from the fuse panel?
Note ..I can't get my hands on a volt meter until tommorrow, thats why I'm asking.
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #2 of 4 (permalink) Old Apr 15th, 06, 02:12 AM
Re: Coil wire question?
I used the original resister wire that went to the coil+ for the points. The small red is only for internal switching and doesn't pull any real current as the big red actually powers the ignition. the small red will "turn on" the box with as little as 4-5 volts so using the original resister wire is not a problem. You don't need the wire from the starter as long as the resister wire is hot in the start position. You can also use the fuse box but the resister wire is better because if the fuse ever blows, car quits running. With a MSD6al the only wires that go to the coil are the small orange and black from the MSD6al. Someone else asked this same question at another site that I just answered http://www.chevelles.com/forums/show...575#post900575
Greg U
undee72Z is offline
post #3 of 4 (permalink) Old Apr 15th, 06, 04:41 AM Thread Starter
Marc
mnm99's Avatar
Well I got bored last night and ran a wire from the fuse panel with a fusible link. Would there be any problem bypassing the two original wires/tape them back and just use the new 12v I ran? MSD calls for 12V so thats what I thought I should do.
mnm99 is offline
post #4 of 4 (permalink) Old Apr 15th, 06, 06:05 PM
Theres nothing wrong with that, i just prefer that the small red is on its "own" circuit. If you still have the original externally regulated charging system, you may need a diode if the car won't shut off with the key.
Greg U
undee72Z is offline
Coil wire connector Larry's 69 Engine 4 Aug 14th, 05 06:19 PM
Brown wire hooked to coil ? MSD Flynn69 Electrical & Wiring 4 Jul 24th, 05 05:24 AM
Coil spring safety question Domano 68 Brakes, Suspension & Steering 5 Jun 3rd, 04 06:38 PM
Coil Spring Question Scott Reeves HSV Brakes, Suspension & Steering 19 Sep 30th, 03 01:42 PM
Welding Question: Mig Wire Size? what is good? Chris Edwards Body Shop 10 Mar 13th, 02 01:28 PM
