Headlamps only working on highbeam not regular. - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 15th, 06, 10:41 PM Thread Starter
Angry Headlamps only working on highbeam not regular.
Help needed.. All lamps work except the regular headlamps. With switch on the highbeams work if I step on dimmer switch, but they will not click and stay on. The regular beams will not even come on. Any ideas???
SB400 is offline
post #2 of 9 (permalink) Old Apr 15th, 06, 11:32 PM
Re: Headlamps only working on highbeam not regular.
Replace the dimmer switch and your headlights will work.
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 9 (permalink) Old Apr 16th, 06, 01:53 AM
john
wagonman's Avatar
yes,,as mentioned b4 its prolly the dimmer switch. but dont rule out the possibilty of both low beams being burt out.
i spent 45 min trying to locate a trouble why all 4 headlamps were not working on a monte carlo..... just to find out that all 4 lamps were out!!!!
i felt stupid.....
wagonman is offline
post #4 of 9 (permalink) Old Apr 16th, 06, 01:54 AM
john
wagonman's Avatar
yes,,as mentioned b4 its prolly the dimmer switch cuz of it not "latching". but dont rule out the possibilty of both low beams being burt out.
i felt stupid.....
wagonman is offline
post #5 of 9 (permalink) Old Oct 23rd, 07, 11:54 PM
Strick
After installing my hydroboost - I now have high beams, but no low beams.
I have NOT even looked for the problem. Yes, I am trying to take the easy way out. Any quick thoughts on what to look for first.
Both high and low worked fine before the install.
Thanks!
Strick
Strick is offline
post #6 of 9 (permalink) Old Oct 24th, 07, 10:05 AM
Sounds like two unrelated issues to me.
Have you changed the dimmer switch on the floor? It is common for those switches to fail. Cheap and easy ( 1 screw) to fix.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #7 of 9 (permalink) Old Oct 25th, 07, 12:03 PM
Arch Stanton's Avatar
Start with the easy stuff.
Mine was simple. The carpet & switch grommet shifted just enough to bind or hang up the switch so it wouldn't click all the way from high beam back down to low beam. Adjusted/moved the carpet. Works fine now.
Replacing the switch is easy though, if it needs to be replaced.
- John
Misfit tortured soul. Lone wolf. Unicorn.
'67 V8 Camaro - 12637, 797-Z (Parchment), M-M (Royal Plum), 2M, 3K, 5Y
Arch Stanton is offline
post #8 of 9 (permalink) Old Oct 25th, 07, 08:47 PM
Strick
Solved = ?? I moved the carpet aligned the wires, which would do zero except maybe fix a short and guess what - works fine. I drove this car from TN to NV last September and never had an issue with the headlights.
Thanks for the suggestions guys. I will probably go ahead and order another switch with my next NPD order.
Strick
Strick is offline
post #9 of 9 (permalink) Old Oct 26th, 07, 07:39 AM
click's Avatar
also clean up those contacts inside the plastic plug, removing them is best to get them really clean. They get alot of moisture and sand and crud in them. Remove with tiny screwdriver to release the tang that holds them in the plastic slot, push out and clean. Gently rebend the tang 'out' just a tiny bit and push back into the plastic hole and its good for years and years
click is offline
anybody ever think about having a working radio in your camaro ? RS3SDL2MG Bench Racing 30 Oct 25th, 07 01:17 PM
Working on Projects? 69camarofast Bench Racing 7 Mar 21st, 06 01:56 AM
Headlights on 69 not working, I have read the threads, still don't work Buildinga55 Electrical & Wiring 12 Dec 8th, 05 09:19 PM
Highbeam switch is dead. How do I fix it? samualt Electrical & Wiring 2 Sep 29th, 05 11:55 AM
67 horns not working jks67SS396 Electrical & Wiring 1 Oct 19th, 01 11:55 AM
