69 Convertible Top Switch Red Wire - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 17th, 06, 11:33 PM Thread Starter
Cameron
I can't find this in the 69 Camaro Wiring Diagram Manual. My electric switch for the conv. top has a red wire. It looks like it has a grommet on it to go through the firewall. And it's about 2 feet long. Does anybody know where this is supposed to go? I assume it needs a positive power source? I hate to admit it that I disassembled the entire car and can't remember where this goes. I have an American Autowire complete kit installed in case that matters. Thanks.
69 Convertible,
criddell is offline
post #2 of 6 (permalink) Old Apr 18th, 06, 01:40 AM
Charles
Re: 69 Convertible Top Switch Red Wire
it probably goes to the firewall mounted circuit breaker beside the brake booster.
the grommet should fit a hole near the fuse block.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #3 of 6 (permalink) Old Apr 18th, 06, 05:07 AM
And then to the horn relay.
Greg U
undee72Z is offline
post #4 of 6 (permalink) Old Apr 18th, 06, 08:20 AM Thread Starter
Cameron
Thanks, but, the American Autowire harness does not have a horn relay or the circuit breaker on the firewall. I'll call AA and see if they have any recommendations.
69 Convertible,
criddell is offline
post #5 of 6 (permalink) Old Jul 11th, 06, 06:07 PM
Cisco
battleax's Avatar
You should have a circuit breaker assembly (4849847) on your firewall above and outboard of your brake booster. The red pigtail has a spade end and a round end. The spade end plugs in near the switch and the round end goes to the circuit breaker assembly (bottom post). The circuit breaker top post has wire assembly (6290627) from the top post to the horn relay on the radiator support. See 1969 Camaro Assembly Manual UPC C06 Sheet A1.
Good Luck
1969 Convertible ZZ4/350 Hotchkis TVS West Coast Diff
battleax is offline
post #6 of 6 (permalink) Old Jul 11th, 06, 09:35 PM Thread Starter
Cameron
The American Autowire harness has several heavy duty accessory plugs under the dash for power windows, updated AC, stereo/amps etc. I plugged the top into one of those on the recommendation of AA.
69 Convertible,
criddell is offline
Converting a hard top to a convertible #1camaro Convertibles 49 Aug 3rd, 17 06:11 PM
Horn relay wire became red hot - allmost a fire efd75 Electrical & Wiring 10 Jul 24th, 05 11:45 PM
68 vacuum headlights Opening but not closing AAAAGGGG!!! ray moore Electrical & Wiring 11 Jul 7th, 05 05:01 PM
Convertible Top with two small slits? reamo1 Convertibles 2 Jun 14th, 05 07:21 PM
Power Convertible Top Switch - Help With Reassembly! dschribs Electrical & Wiring 2 Feb 6th, 04 11:16 AM
