Voltmeter installation??? - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 19th, 06, 01:16 PM Thread Starter
I've recently bought a 69 convt. with an aftermarket volt meter. Where do the wires connect to?? I was told poss. goes to the battery, and the neg. is grounded under the dash. When I attempt to connect to the battery, I'm getting a spark (shorting out) Any help...please???
Dan 69 is offline
post #2 of 10 (permalink) Old Apr 19th, 06, 01:43 PM
Re: Voltmeter installation???
The voltmeter positive connection "can" be connected to any hot lead on the car. I usually use the ignition circuit so the gauge powers off when I turn off the key.
Are you talking a spark when you connect the main battery cable, or something added? A big spark or a little one?
A little spark would not be unusual if the car's door is open, or if there is a modern stereo or clock in it.
post #3 of 10 (permalink) Old Apr 19th, 06, 01:43 PM
Vintage 68's Avatar
Is it a "Voltmeter" or an Ampmeter ???
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 10 (permalink) Old Apr 21st, 06, 02:04 AM
Craig
If its a voltmeter just hook a hot lead into fuse panel ignition, so it only comes on when car is on, and then just make sure you hook up a good ground. Should work fine
1968 454 TH350 Red with Black vinyl top
cmking26 is offline
post #5 of 10 (permalink) Old Apr 21st, 06, 05:19 AM
I hook my voltmeters directly to the battery hot lead so they are on all the time so I don't have to turn on the key to see if the battery is up to voltage.
onovakind67 is offline
post #6 of 10 (permalink) Old May 1st, 06, 05:55 PM Thread Starter
I've tried several times to hook it up to different hot wires...same thing. After looking at the gauge, it only has a pic of a battery. with a 60 on each side of the needle, and a 0 inthe middle.
Dan 69 is offline
post #7 of 10 (permalink) Old May 1st, 06, 08:07 PM
prostreet69camaro's Avatar
That is a AMP guage not a VOLT guage. You have to put it in series with the main power wire to see how many amps your circuits are drawing. You need to connect it between the #10 wire that goes from the battery to the terminal block on the firewall behind the battery.
I personally do not like a amp guage. I would install a volt guage. The reason it is sparking is because the current goes thru the guage and when you ground one side and connect 12vdc to the other side it is a dead short.
prostreet69camaro is offline
post #8 of 10 (permalink) Old May 1st, 06, 10:07 PM
Steps
I agree...I dont figure why cars have ampmeters, they dont really tell As much usefull info as what a voltmeter does.
Steptoe is offline
post #9 of 10 (permalink) Old May 2nd, 06, 09:45 AM
Vintage 68's Avatar
Wink Re: Voltmeter installation???
1968 Convertible
Some trucks
post #10 of 10 (permalink) Old May 4th, 06, 10:18 AM Thread Starter
Ah....That makes sense. I'll have to find a volt meter that works with the other gauges. Thanks alot for the help!
Dan 69 is offline
Windshield installation John3366 Body Shop 11 Apr 22nd, 06 07:44 AM
Moser Installation Notes Meanchicken Transmission & Driveline 3 Apr 8th, 06 09:09 AM
AMP Gauge 67 RS CONV Electrical & Wiring 3 Mar 1st, 06 09:14 AM
In-Dash Tach installation Dandeuce Electrical & Wiring 4 Jul 29th, 02 09:04 AM
68 Front Bumper Guard Installation Robert Stacho Tech 2002 6 May 1st, 02 03:35 AM
