grounds - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 20th, 06, 05:38 PM Thread Starter
grounds
If I want to go around my car and check to make sure i have all the necessary grounds for everything, which places are key spots to look for the main grounds?
Thanks, James
jheabs is offline
post #2 of 8 (permalink) Old Apr 20th, 06, 05:41 PM
click's Avatar
Re: grounds
what car, what year?
click is offline
post #3 of 8 (permalink) Old Apr 20th, 06, 05:43 PM Thread Starter
Re: grounds
sorry, forgot the key information. 1968 Camaro convertible with a 350 v8 automatic
jheabs is offline
post #4 of 8 (permalink) Old Apr 20th, 06, 05:46 PM
Paul
Re: grounds
What year is your Camaro. The main ones I know about for the engine bay of a first gen are
battery to the body from the negative cable
Firewall to engine (usually the passenger's valve cover)
Firewall to subframe (lower passenger's side cowl)
Negative battery cable to the block.
There have to be 50 others in the car that include the blower motor, dash lights, headlights, parking lights etc... Basically, every electic device in your car needs a ground to complete the circuit.
Are you having a particular problem w/something in your car? A factory assembly manual is an awesome place to see diagrams of where all these grounds should be.
Let us know if you have any specific questions
1967 Camaro RS 350, Tremec 5spd, Hotchkis, Frame off
Bought it
Rebuilt it
Almost done
oakster is offline
post #5 of 8 (permalink) Old Apr 20th, 06, 05:49 PM Thread Starter
Re: grounds
Where would the one's for the dash lights, and turn signals be located?
jheabs is offline
post #6 of 8 (permalink) Old Apr 20th, 06, 05:57 PM
Paul
Re: grounds
It is a wire that goes from the back of the guage cluster to the top middle screw holding the cluster to the dash. The wire is like a paperclip that is bent to line up with the screw.
A lot of people have issues w/this ground and have run another ground from the cluster to a better ground.
Bought it
Rebuilt it
Almost done
oakster is offline
post #7 of 8 (permalink) Old Apr 22nd, 06, 05:05 AM
Marc
mnm99's Avatar
Re: grounds
Sorry to steal this thread,but I have a question about a ground too. I have all you mentioned. I just installed a complete MSD system 6AL, coil, dist and have a buzzing in my radio. I was told to put a ground from the ENGINE TO FRAME. I don't see one of those, only all you listed. Do I need one?
I guess I will try MSD's noise filter after all my grounds are correct. Thanks
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #8 of 8 (permalink) Old Apr 22nd, 06, 05:22 AM
Re: grounds
Cars that came with AM radios had a "Noise suppresion kit". In 68 This was 3 copper braided ground straps, one from each valve cover to the firewall, and one from the subframe to the firewall on the pass side. These are detailed in the AIM, and available repro.
Also, many of the important grounds are up front, on the rad support, including ground wires for the parkling lights, headlights, and the most important, the voltage regulator.
I use star washers between the terminal and the sheetmetal on all my ground connections. They cut through that new paint and make a good connection.
Also, I ended up running he ground pigtail from the neg bat cable to the rad support rather than the inner fender as shown in the aim. With all the new paint, I just wasn't getting a good ground circuit from the inner fender to the outer and then to the rad support thru all the normal attaching bolts.
67 RS front turn signal grounds Kyson Electrical & Wiring 2 May 8th, 05 08:49 AM
where are instrument panel grounds? llpainter Electrical & Wiring 0 Apr 17th, 05 04:51 PM
New Camaro Arrives At G.m. Proving Grounds Today!!! BBC1 Bench Racing 14 Apr 4th, 05 07:59 AM
Grounds? DaveSS350 Electrical & Wiring 1 Mar 3rd, 03 01:23 AM
Console Grounds??? BelgianSS Electrical & Wiring 4 Dec 1st, 02 10:03 AM
