Removing 68Z Distributer Cap? - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 21st, 06, 03:31 PM Thread Starter
Brad
Will removing the distributer cap on my 68Z cause any thing to change setting-wise? I've been looking it over to see if it's a real-deal 1968 1111467, but can't seem to see any writing on the bare aluminum, or around the back by the rear of the motor. If it were a real 1111467 distributer, would the part number be visible without removing the cap?
Camaroless and hating it
chedderboy is offline
post #2 of 6 (permalink) Old Apr 21st, 06, 05:34 PM
Vince
Re: Removing 68Z Distributer Cap?
Nothing should change and as memory serves you should be able to see the number.Wish I still had my u-2 paint code 68 RS Z!!!!!
3forme is offline
post #3 of 6 (permalink) Old Apr 22nd, 06, 02:56 AM
TDW
Tony
You can see the number if you use a telescoping mirror and a flashlight. The number will be at the back of the dist, on the housing. It is not necessary to remove the cap, as the numbers are lower than where the cap sits.
TDW is offline
post #4 of 6 (permalink) Old Apr 22nd, 06, 10:21 AM Thread Starter
Brad
Thanks for the suggestion! I just happened to have a telescoping mirror in my ready bag. The only problem is that the numbers are faint and backwards! Now it's really driving me crazy, as I think my car might still have the original 1111467 distributer! I'm thinking I might be able to photograph the image in the mirror and transfer it to the computer to enhance it a little...
post #5 of 6 (permalink) Old Apr 24th, 06, 08:33 PM Thread Starter
Brad
SCHWING! The mirror trick worked! It's hard for me to believe, but my 68Z has the original 111467 distributer! Thanks for the info!!
post #6 of 6 (permalink) Old Apr 25th, 06, 03:18 AM
TDW
Tony
Glad it worked.
TDW is offline
Leaking gas cap! ebd Camaro Tech 2 Feb 13th, 06 11:38 PM
ss cap blue67 Restoration Corner 2 Jan 29th, 06 06:26 PM
New rings and bearings on a used engine. MarkM Engine 7 Jan 4th, 06 04:42 PM
Distributer Install Help freebird Engine 3 Aug 10th, 05 01:18 PM
Help with '68 Wood Steering Wheel Horn Cap Installation on a Tilt column ggkeller Interiors 2 Jun 29th, 05 05:32 PM
