Coil Wire - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 22nd, 06, 01:44 PM Thread Starter
Coil Wire
I have now upgraded to the Petronix module in the distributor and a MSD coil. The yellow wire going to the stock coil is from the starter solenoid. Can I now leave this wire off since I no longer have points and condensor?
Charles Brown is offline
post #2 of 6 (permalink) Old Apr 22nd, 06, 02:02 PM
Re: Coil Wire
possibly, if the resistor wire has power while cranking the engine, you do not need the yellow wire, but it may be hard starting (because of the lowered voltage without the yellow wire)
but, because you dont have points and you have an mds coil, you could run full 12v to the coil from the fuse box (or cut out and replace the resitor wire) and then you will not need the yellow wire
400bird is offline
post #3 of 6 (permalink) Old Apr 22nd, 06, 09:18 PM
Re: Coil Wire
You do need the yellow wire going to the starter. It supplies the voltage to the the coil. You will need the 12 volts to the coil at initial start-up. You can remove the resistor wire and replace it with a new wire that will supply the coil with 12 volts after start up.
Camaro buds until the end!!!
Camaro Dave is offline
post #4 of 6 (permalink) Old Apr 23rd, 06, 09:13 PM
Re: Coil Wire
so dave are you saying that the resistor wire doesn't have voltage when cranking?
400bird is offline
post #5 of 6 (permalink) Old Apr 23rd, 06, 11:08 PM
Re: Coil Wire
It is my understanding that the starting circuit works by the yellow wire supplying 12 volts to the coil when the engine is cranking over. As soon as the key returns to the on position, the ignition switch then will supply power to the resistor wire cutting down the voltage to 8 volts to the coil. The reason is to lower the voltage to the coil to keep the points from burning out prematurely. If you remove the yellow wire then the coil will not get 12 volts to fire the engine when the key is in the start position.
post #6 of 6 (permalink) Old Apr 24th, 06, 07:44 PM
Re: Coil Wire
thanks dave, i was unaware that voltage was cut from the resistor wire while cranking
400bird is offline
PO 300 301 302 OBD II 3L 4P Bench Racing 9 May 6th, 05 07:02 PM
Generator light problem - coil, HEI module, resistance wire, ignition switch? mr69 Electrical & Wiring 2 May 29th, 04 07:19 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 01:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 01:57 PM
ignition coil +resistance wire getting extremely hot jlighthart Electrical & Wiring 1 Jun 3rd, 01 11:57 PM
