Back up lights without lockout rod? - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 22nd, 06, 02:00 PM Thread Starter
Jimmie-Retired
I have a 69 4 spd car and didn't like having to put the car in reverse to get the ignition key out so I removed the lockout rod and removed the backup light switch so that they didn't burn all the time. Has anyone rigged up a backup light switch using the reverse lever off the trans to trigger the backup lights? Part # or source of switch? Does the green wire complete the circut off of the back up light switch? Thanks, Jim
Jim's '69
68 SS 396 4 speed A/C Bought New Sold 1976
68 350/350 A/C Bought 1978 $700 Wrecked
69 350 4 Speed Bought 1988
Fried Okra is offline
post #2 of 4 (permalink) Old Apr 22nd, 06, 03:14 PM
Kevin
SixtyAte's Avatar
Re: Back up lights without lockout rod?
I used a Hurst switch available from any Hi Pro parts store.
HUU-2480003 Switch and Bracket, Back-up Light, Competition Plus/ Super Shifter 3/ Master Shift, Each $23.69
Kev
SixtyAte is offline
post #3 of 4 (permalink) Old Apr 22nd, 06, 03:18 PM
on a 68, the pink / bk stripe wire is the power feed, and green goes back to the lights, 69 should be the same. Just extend them back to the hurst switch.
Or, you can just rotate the cylinder at the base of the column to trn them on.
post #4 of 4 (permalink) Old Apr 23rd, 06, 06:45 AM
I originally used the hurst switch, and got sick of it working intermitantly. I then adapted the 68 switch setup and linkage. I had to drill a small hole in the reverse rod for the linkage but it works perfectly. MOst people haven't had any issues with the hurst switch. Good Luck.
Dave69Z is offline
Brake Pedal Doesn't come all the way back up- Lights stay on.. 1967rsss350 Troubleshooting 13 Mar 10th, 16 01:05 PM
my header bolts love to back out and blow my gasket importkiller69ss Performance 10 Apr 8th, 06 07:20 AM
350 rods 400 block? zachs camaro Performance 10 Aug 19th, 05 08:12 AM
RS back up lights flpenguin Electrical & Wiring 4 Sep 29th, 04 07:19 AM
back up lights mike brown Tech 2000 5 Feb 2nd, 00 08:27 AM
