Fuel Pump mounting locations for '67-'68. - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 24th, 06, 06:02 AM Thread Starter
I'm in the process of mocking up my electric fuel pump location. I want to tuck it away so it's not seen so much but from what I remember I thought it had to be mounted lower than the tank itself in order to work properly.
What I need are some pictures of how and where electric fuel pumps have been mounted on '67 and '68's to get some general ideas. Thanks.
1968 Pro-Touring Camaro.
Infamous is offline
post #2 of 6 (permalink) Old Apr 24th, 06, 06:34 AM
Re: Fuel Pump mounting locations for '67-'68.
If you don't use a crossflow muffler, there's plenty of room between the tank and the axle. I've seen them attached to a flat plate hung from the trunk floor. You can get the pump down almost level with the bottom of the tank and still have it invisible. I did this once with an external pump efi setup, with the pump and 2 filters attached to the plate, worked great and was completely invisible.
post #3 of 6 (permalink) Old Apr 24th, 06, 11:43 AM Thread Starter
Thanks Jim.
Infamous is offline
post #4 of 6 (permalink) Old Apr 24th, 06, 11:48 AM
I think mines mounted on the rear frame rail, I'll see if I can find some pics.........KZ
kz1000ltd is offline
post #5 of 6 (permalink) Old Aug 21st, 09, 04:17 PM
Jeff
pics please!!! A1000 if possible
thanks
1967 SS 396, M20.
now a 10.4:1 540, AFR 315 heads, UDHarold SR Cam with a Tremec TKO
jks67SS396 is offline
post #6 of 6 (permalink) Old Aug 22nd, 09, 05:27 PM
Greg
Here ya go. A1000 mounted up and the plate I used in the trunk to reinforce it.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, street car, Water/Meth injection
1.302 60', 5.956 @ 116.4 Super Sniper EFI 2019
Greg O is offline
fuel pump & fuel cell suggestions needed bills68camaro Performance 3 Apr 3rd, 06 05:05 PM
Fuel pump question 69RS-Yenko Performance 2 Mar 25th, 06 09:32 AM
ZZ383, fuel pump Nonni Performance 9 Jan 31st, 06 06:58 AM
Removing Fuel Pump Push Rod? Brian Lewis Engine 10 May 1st, 05 05:57 PM
Convertible pump mounting help? jrager Tech 2002 4 May 29th, 02 05:42 AM
