electrical turn singal problems - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 24th, 06, 10:19 PM Thread Starter
Question electrical turn singal problems
I tryed to figure out this problem and failed badly, the problem on my 86 camaro is when you use the turn signal left or right all lights try to blink at the same time. also when I turn on the light switch and turn the turn signal with key in the off position the insterment warnings light cluster will come on until you turn the key in the on position. I change the turn signal switch with a new one but did not help, instead it created a different problem, whats going on? and how can I fix this problem Thanks for reading this message Tom.
86 red camaro is offline
post #2 of 4 (permalink) Old Apr 27th, 06, 07:46 PM
Kevin
SixtyAte's Avatar
Re: electrical turn singal problems
Sorry,
You have a major problem somewhere with the wiring. Are the 4 way /emergency flashers on?
Kev
SixtyAte is offline
post #3 of 4 (permalink) Old Apr 27th, 06, 09:59 PM Thread Starter
No, the four way flashers work the way suppsoe to some one said there might power back feeding some where.
post #4 of 4 (permalink) Old Apr 27th, 06, 10:37 PM
Steps
Bad earth ?
Steptoe is offline
No right rear turn signal or hazard Obxhokie Electrical & Wiring 6 Jul 9th, 06 06:00 PM
electrical problems 70camarro Electrical & Wiring 5 Apr 9th, 06 07:37 PM
starting problems DL Engine 4 Jul 13th, 04 02:31 PM
Arrrrrrrggggggggggggg....electrical problems..engine wont start.. kel Troubleshooting 11 Sep 6th, 01 04:05 PM
BRAKE lights OUT when USING THE TURN SIGNALS KED67 Electrical & Wiring 5 Jun 26th, 01 03:40 PM
