1967 electric hide0away headlights - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 25th, 06, 10:53 AM Thread Starter
Cool 1967 electric hide0away headlights
I have these lights. Both sides open well. However the passengers side doesnt open with enough force to shut off the motor when it hits the switch. On the drovers side (when open) i cant move the door by hand. However onthe passengers side i can easily move the door as if there were no gears holding it. Im a little confused. I thought I read that the doors opened with plastic gears, if this is true i should not be able to close the passenger side door unless the gears were striped. If they are stripped then how are they opening.. where are the gears located so i can look at them.
Hgoy is offline
post #2 of 5 (permalink) Old Apr 25th, 06, 03:04 PM
Joe
Re: 1967 electric hide0away headlights
I had my system all taken apart about a year or two ago, and as I recall, the arm that connects to the door has a keyed washer on each side. The motor's shaft fits through these washers. A nut ot bolt holds the washers together around the arm with thin flat friction washers between each big washer and the arm. the nut should be loose enough that you can open the doors by hand but still tight enough that the motor can turn the arm without slipping.
I believe the motor has 4 rivets holding the end on. The inside of the motor has teeth that the gears hold on to. The gears are stacked up inside the motor. I took mine apart, and one motor was stripped out, the other one i cleaned out and regreased. I bought stainless screws and I then tapped threads into the motor housing and screwed the motor end back on with these screws and that replaced the rivets I drilled out.
The gears are 4 small gears sitting on a little round plate. there is another set of gears underneath those too. It can be tricky taking it out and putting it back in without it coming apart, but I just used lots of grease to hold it together when I put it back inside the motor. It's kind of hard to explain the gears, but it makes sense once you see them. Checking the gears will require you to completely remove the motor from the headlight housing, which takes a little patience, but can be done.
It sounds like you could first try loosening the nut on the arm of the door that won't open so that you can move it yourself, and also try tightening the nut on the arm of the door that has the running motor so that it will come back firmly against the off switch. I would try that before going to the trouble of removing the motors.
67 RS with 4 barrel smallblock 350. See the USA in your Chevrolet...
Eighttrakz is offline
post #3 of 5 (permalink) Old Apr 25th, 06, 06:13 PM
I agree. Try tightening the nut on the bottom of the motor output shaft. I beleive that should fix your problem.
Marktat is offline
post #4 of 5 (permalink) Old Apr 25th, 06, 09:41 PM Thread Starter
Thanks for the info guys!! Ill give the thghtening and loosening thing a try . I realy dont think I want to take all that stuff apart!! let you know how it works out!
Hgoy is offline
post #5 of 5 (permalink) Old Apr 27th, 06, 08:02 AM Thread Starter
tightened one and it worked great. loosened the other not much difference (still cant close it by hand) gonna try to lossen it a bit more. The main problem is sloved thought the motor no longer runs constantly when the passengers side light opens becasue it is no holding tight enought to activate the radiator limiting switch!!! Thanks guys for your help!!!
Hgoy is offline
Electric RS Closing Headlights criddell Body Shop 15 Apr 19th, 05 07:54 AM
Did all 1967 Rally Sports have hideway headlights? MangeMD Body Shop 10 Dec 12th, 03 11:45 AM
Did all 1967 Rally Sports have hideway headlights? MangeMD Tech 2003 3 Dec 8th, 03 01:06 PM
RS Headlights Electric or vacuum? sixt9d Tech 2001 7 Jan 9th, 02 08:44 AM
RS headlights, electric or vaccum? which is better? jvolk81 Tech 2000 9 Jan 2nd, 01 05:03 AM
