95 ignition problem - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 25th, 06, 03:08 PM Thread Starter
95 ignition problem
Hi Guys I'm new to this forum. Been watching in the back ground for awhile. I am having a problem with my 95 it has a 3.4 litre 5 speed. When I turn the key nothing happens for a while if I turned the key hard it would start now nothing. Yhis is what I have done so far but with no results. I changed the clutch sensor. The ignition switch down on the column battery and starter, I don't think there is much more to change but it still wont start. Any help will be greatly appreciated. Thanks Ed
dads95 is offline
post #2 of 6 (permalink) Old Apr 25th, 06, 04:57 PM
Jeff
Re: 95 ignition problem
Ed,
Is the security light flashing on the dash? If it is, your ignition switch may be bad. There is a chip in the key that must make contact with the ignition switch. That's what happened to me and of course on a Friday at work.
Jeff
jeff_gates is offline
post #3 of 6 (permalink) Old Apr 25th, 06, 05:11 PM Thread Starter
Jeff
The light goes out as soon as I turn the key it doesn't flash. I don't know if there is another switch or relay after the ingition switch and before the starter.
Ed
dads95 is offline
post #4 of 6 (permalink) Old Apr 26th, 06, 01:01 PM Thread Starter
does anyone know about a starter engage module. They say its behind the IP on the right side of the radio. What do they mean by IP
dads95 is offline
post #5 of 6 (permalink) Old Apr 28th, 06, 02:19 PM
Kevin
SixtyAte's Avatar
IP= Instrument Panel
Kev
SixtyAte is offline
post #6 of 6 (permalink) Old Apr 29th, 06, 06:53 PM Thread Starter
Thanks Kev feeling a little dumb now. Well I found the problem It was the ignition switch. The new I got from the supplier was also bad. Starting like it should. Thanks again for the come back.
Ed
dads95 is offline
2001 Z28 ignition switch/security system malfunction 45Auto Electrical & Wiring 3 Sep 22nd, 05 08:19 AM
Ignition problem 68bbconv Electrical & Wiring 3 Sep 13th, 04 01:57 AM
Ignition switch problem michwalt15 Electrical & Wiring 0 Apr 27th, 03 01:44 PM
Ignition Timing Strange Problem Mean 69 Engine 29 Apr 4th, 02 10:10 AM
Ignition timing problem boomer54 Tech 2000 3 May 24th, 01 06:18 AM
